Team Magic E4 Thread >
Old 01-25-2010, 09:27 PM
  #3001
05forfun's Avatar
Trader Rating: 81 (100%+)
Free bump for a sweet car
05forfun is offline
Old 01-27-2010, 11:49 AM
  #3002
wyd
wyd's Avatar
Trader Rating: 51 (100%+)
Originally Posted by Troy Mckune
I am selling my E4RS DE level 3 with 3mm chassis, original 2.5mm chassis, new Lipo top deck and spacers, and many spares and NIP parts.
Check it out at:
http://www.rctech.net/forum/r-c-item...level-3-a.html
Damn I wish I had the cash as I would take it. That is an awesome ride.
wyd is offline
Old 01-27-2010, 12:25 PM
  #3003
blis's Avatar
You're not the only one drooling.
blis is offline
Old 01-27-2010, 01:48 PM
  #3004
Pro10noob's Avatar
Trader Rating: 13 (100%+)
Drools bigtime
cheers Roy
Pro10noob is offline
Old 01-28-2010, 11:21 AM
  #3005
wyd
wyd's Avatar
I feel like I need a drool cup.
wyd is offline
Old 01-30-2010, 05:57 PM
  #3006
Isaac's Avatar
The E4 at the Coliseum in Frederick, MD = fun! As traction came up I had more traction rolling but before that the car was very fast and very smooth. I got many compliments. I smoked a motor but it was fast before then . Duos surely do not work as I had to get a specific spur to make gearing work.
Isaac is offline
Old 02-01-2010, 05:21 PM
  #3007
Isaac's Avatar
Isaac is offline
Old 02-01-2010, 05:33 PM
  #3008
Ray k's Avatar
Trader Rating: 47 (98%+)
If I was not holding the temp gun ,I wouildn't of believed it , 336 degs. LOL
Isaac ,step away from the Tekin software please !!!!!!!!
Ray k is offline
Old 02-01-2010, 05:36 PM
  #3009
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
HOLY SMOKES....i wondered what ray was doin in a TM thread haha.
i have 17.5 duos and duo2s F/S (shameless plug)
R
UltegraSTI is offline
Old 02-02-2010, 06:28 AM
  #3010
Isaac's Avatar
It's ok Ray I will be back... The E4 was good at the Coliseum.
Isaac is offline
Old 02-02-2010, 11:57 AM
  #3011
Isaac's Avatar
Has anyone fitted a LRP X-12 motor into the E4 chassis? I need conformation that the motor fits before purchasing. The Duos are certainly too big.
Isaac is offline
Old 02-02-2010, 12:17 PM
  #3012
Trader Rating: 17 (100%+)
I used DUO 2 on my E4RS (17.5)....yes, it does required some grinding on the alum side belt tensioner mount but once that is done, I can move full forward and backward within the motor bay and gear like 10-12 range...
Solara is offline
Old 02-02-2010, 12:27 PM
  #3013
Isaac's Avatar
I just used a DUO2 last weekend. I will look again and see how much I have to grind off and if I want to. If not I have a OHP Duo2 for sale with two 6 minute runs on it.
Isaac is offline
Old 02-02-2010, 12:42 PM
  #3014
wyd
wyd's Avatar
I dremeled my side belt tensioner alot so I could get a good amount of motor movement when I used the DUO and Tekin motors. I never dremeled any of my alum motor mount but instead chose to take off the left side aluminum mount and install the motor and then put the left mount back on. Only took me a few minutes but I didn't need to grind the rear alum mount any.
Isaac as long as the end of the motor is rounded like the old Novaks, LRPs and the newer Novak motor you shouldn't have any fitament problems. IF the motor end is like the Tekin or Trinity where it is perfectly squared corners then it will require you putting the motor in the way I sugested and then a good amount of dremel action on the belt tensioner.
It took me about 20 minutes or more to really dremel my side belt tensioner down but once done I gained alot of motor movement. I just never had time to really make a new side tensioner so I could remove the plastic one all together.
Isaac check with Wolf at Wolfs Hobbies as I thought he was in the process of making a new side tensioner back when I had mine. Maybe he has some newer ones that are cut to give more room.
wyd is offline
Old 02-02-2010, 03:31 PM
  #3015
Isaac's Avatar
Solara helped me out. Good picture Solara. I will check with Wolf and see what he says about a new motor mount.
Isaac is offline
