Team Magic E4 Thread >
Old 02-02-2010, 06:07 PM
  #3016
Trader Rating: 24 (100%+)
I run a Fantom Racing ION motor. 17.5 I had to shave just a hair off the belt tensioner as well to just fit the motor. I just bought a plastic one and it works great. The Fantom Ion motor is supposed to be the same motor as the Epic Duo 2's. So I knew from a previous thread that this would have to be done.
Updates. Last weekend ran at a local track that I had never been to before. It is a low/medium traction asphalt. After talking with the sorex guys, it appears as I was running the wrong tire compound. I was running 36's cause everyone else was. I went to the 28's and was stuck to the track. I ran this setup: http://www.petitrc.com/reglages/team...ly20090426.pdf
When I was running the sorex 36's, I had alot of tailspinout. I also had my esc setup with alot of dragbrake and 70% power profile. Took all but 10% drag brake out and set the power profile to like 45%. Alot easier to drive! And with the right tires, I finally got to see my car drive well! Awesome car. Getting alot of comments on my abilities improving. But with the car setup right, it makes it just so darn easy to drive! I will however be increasing the power as ability permits. Would like to be able to drive mod class one day. But so far, all suggestions were awesome and the combination of getting the spring set and borrowing a setup board and tools, I couldn't be happier with my car! Thanks guys, Vinny
vinny73 is offline
Old 02-02-2010, 06:11 PM
  #3017
We were running 2 - 5 minute qualifiers and 1-6 minute main. By the end of the last race, at 5 minutes I had gained a lap and a half, 22 seconds, from my 1st race. Granted, I got used to it, the track that is, but making the proper changes from everyones input, 1 at a time made a world of difference. I got in as much practice as I could and am now not totally hitting everything! Allmost got the whole "drive in the center of the track and slower is faster" nailed! So, getting there! Vinny
vinny73 is offline
Old 02-02-2010, 06:30 PM
  #3018
Isaac's Avatar
Sounds good Vinny I'm happy you enjoyed the car. It is true once the car is set up it's fast and very easy to drive.
Isaac is offline
Old 02-03-2010, 08:17 AM
  #3019
rced1's Avatar
Trader Rating: 17 (100%+)
Can someone tell me what the spring rates are for the team magic purple and pink springs for 1:10?
rced1 is offline
Old 02-03-2010, 08:34 AM
  #3020
Pro10noob's Avatar
Here ya go
cheers Roy
http://www.rc-mushroom.com/product_i...ducts_id=14040
Light Green = 1.2mm
Maroon = 1.3mm
Pink = 1.4mm
Purple = (Rear) 1.5mm
Turquoise (Fronts) = 1.6mm
Blue = 1.7mm
Orange = 1.8mm
Grey = 1.9mm
Pro10noob is offline
Old 02-03-2010, 09:23 AM
  #3021
rced1's Avatar
Originally Posted by Pro10noob
Here ya go
cheers Roy
Light Green = 1.2mm
Maroon = 1.3mm
Pink = 1.4mm
Blue = 1.7mm
Orange = 1.8mm
Grey = 1.9mm
Thanks, and when I combine that chart with the chart from p 195 I get the rate in lbs:
1.2mm 10lb
1.3mm 13lb
1.4mm 17lb
1.5mm 20lb
1.6mm 26lb
1.7mm 31lb
1.8mm 41lb
1.9mm 51lb
Light Green = 1.2mm 10 lb
Maroon = 1.3mm 13lb
Pink = 1.4mm 17lb
Purple = (Rear) 1.5mm 20lb
Turquoise (Frts) = 1.6mm 26lb
Blue = 1.7mm 31lb
Orange = 1.8mm 41lb
Grey = 1.9mm 51lb
rced1 is offline
Old 02-03-2010, 09:30 AM
  #3022
Isaac's Avatar
Light Green = 1.2mm - 10lb
Maroon = 1.3mm - 13lb
Pink = 1.4mm - 17lb
Purple = (Rear) 1.5mm - 20lb
Turquoise (Fronts) = 1.6mm - 26lb
Blue = 1.7mm - 31lb
Orange = 1.8mm - 41lb
Grey = 1.9mm - 51lb <<< where one would use that I don't know
Isaac is offline
Old 02-04-2010, 09:22 AM
  #3023
Issac, did you get the belt tensioner/motor bay worked out..?
Solara is offline
Old 02-04-2010, 10:17 AM
  #3024
Isaac's Avatar
I have not started yet. This weekend is rebuild weekend since we will be hit with 24 inches of snow, so I will do it then. It would be nice to run Duos and Orion motors. Wolf has a shipment for me and it should be here tomorrow.
Isaac is offline
Old 02-07-2010, 12:31 PM
  #3025
Isaac's Avatar
Did the belt tension mount. Motor has a lot room to move now. See the space between the motor and rear pulley. Happy that I can basically use any motor. It was one of two minor things I did not like about the car.
Isaac is offline
Old 02-07-2010, 01:47 PM
  #3026
blis's Avatar
Default Younger son is happier
My younger son felt like his wiring was messy...not entirely sure the coiling is a good idea... "but the BIG boys do it dad!!"
So here it is...
Shortened fan wire, shortened ESC->RX.. oh.. and an OUTLAW ORION 10.5! It keeps him smilin at the back of the field and he still loves his E4
blis is offline
Old 02-07-2010, 05:31 PM
  #3027
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Did you just Dremel the stock plastic tensioner a good amount or make your own?
wyd is offline
Old 02-07-2010, 07:11 PM
  #3028
Isaac's Avatar
dremeled the plastic
Isaac is offline
Old 02-07-2010, 07:22 PM
  #3029
05forfun's Avatar
Trader Rating: 81 (100%+)
Default E4JS for sale here
Is anyone looking for a nice E4JS?
http://www.rctech.net/forum/r-c-item...ml#post6972011
05forfun is offline
Old 02-09-2010, 09:01 AM
  #3030
Born2Run's Avatar
Guys im looking for the TM E4RS '09 manual.Could someone tell me if there is one and where i can find it?I just won the car on ebay and im looking for the manual.Thanks
Born2Run is offline
