Team Magic E4 Thread
#3152
The problem is that so far I've only seen these available for Xray and Tamiya.
They're made by SpecR Competition. Perhaps someone can find a set that will work on the E4.
#3153
If your front wheels are perfectly balanced (or very close across left to right), while running spool, it will not vibrate, or at least it will vibrate very little....however, if you are racing your car on the track (with load) those vibration will not occur compare to you bench testing the car without load. I mean, how can you tell the front wheel is vibrating while running 35 mph on the track?
1 other thing you can do is limit the total steering range (full left or full right)...go like 95% only, not full turn....that will also extend the life of the CVD up front.
Those double jointed CVD that posted above might help a little, but $60 a pop and probably will last you 2-3 races...is alittle bit expensive for me (we have a box full of those broken CVD from the Xray owners and Corally drivers that tried to convert it to work on their PHi). Remember...it is the era of TEKIN 203 with 13.5 motor that can run as fast as MOD motor...with those kinda power, not too many parts can last with impact.
#3156
More info pls.. will check ours soon.. down atm
#3158
If you want to see why the WHEEL/TIRES make the vibration, take of the wheel/tires and do the same thing, even turn full left and right and there are almost has no vibration (when without tires).
I stop care about the vibration years ago....I care about the lap times only.
#3159
hai guys ~ i new at TM E4D
i notice that the rear belt skipping ~ even i have read at previously there is someone have this problem.. but still i can't find where to adjust.. or mb the E4D don't have the "belt tension'
a picture will help.. funny thing is i play rc 15yrs but with belt driven car i am totally NOOBBBBBB !!!
#3163
My E4JS didn't come with a rear belt tensioner so I doubt the E4D will either.
Here's the part you need to order:
http://www.wolfhobbies.com/E4_Parts-...ioner_Set.html
