Tekin RS ESC sensored
#8221
double post
#8222
Dreamdrifter- I would keep the same ratio for now, arrive early for some open practice and temperature check the motor after 4 minutes and see how things are. (assuming you're in 5 minute races).
Sometimes the track size/layout doesnt warrant a gear change, sometimes it will
#8223
i would add a little more delay and work it back up after a few test runs
#8224
Guys I am really sorry as I am sure this has been asked a million times before in this huge thread but I hope you can save me looking all the way thru it!!
I currently race 13.5 and 10.5 in TC are there any advantages to having the RS Pro for these classes over the RS?
Thanks for your help
#8225
apparently not, the pro is mod racing
#8226
I am sure I read somewhere that the Pro has double the amount of FETS?
Does this affect how smooth it is and how strong the brakes are??
#8228
Opening up the RS Pro case
Hi. Was wondering if anyone has opened up their RS Pro cases before. I happened to damage the insulation on my signal leads and need to do some repair work to them.
Some pointers wld be much appreciated. Not very sure where the catches are for the case. Thanks.
#8229
If it's in a place outside the speedo, you can cut and splice out there. It's a lot safer and all you need is a little bit of shrink tube.
#8232
#8235
