Old 11-20-2009, 03:23 AM   #8221
tc3team's Avatar
double post
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-20-2009, 03:24 AM   #8222
tc3team's Avatar
Dreamdrifter- I would keep the same ratio for now, arrive early for some open practice and temperature check the motor after 4 minutes and see how things are. (assuming you're in 5 minute races).
Sometimes the track size/layout doesnt warrant a gear change, sometimes it will
Old 11-20-2009, 06:54 AM   #8223
Senna Racing's Avatar
i would add a little more delay and work it back up after a few test runs
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 11-21-2009, 04:27 AM   #8224
Guys I am really sorry as I am sure this has been asked a million times before in this huge thread but I hope you can save me looking all the way thru it!!
I currently race 13.5 and 10.5 in TC are there any advantages to having the RS Pro for these classes over the RS?
Thanks for your help
008-Racer is offline   Reply With Quote
Old 11-21-2009, 04:45 AM   #8225
apparently not, the pro is mod racing
Old 11-21-2009, 05:04 AM   #8226
I am sure I read somewhere that the Pro has double the amount of FETS?
Does this affect how smooth it is and how strong the brakes are??
Old 11-21-2009, 05:35 AM   #8227
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you wont see any difference in the two with high turn motors
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-21-2009, 05:57 AM   #8228
Default Opening up the RS Pro case
Hi. Was wondering if anyone has opened up their RS Pro cases before. I happened to damage the insulation on my signal leads and need to do some repair work to them.
Some pointers wld be much appreciated. Not very sure where the catches are for the case. Thanks.
radwerx is offline   Reply With Quote
Old 11-21-2009, 07:32 AM   #8229
The case is held together with the 4 screws on the bottom of the case. I really wouldn't recommend soldering on the board unless you're really good at soldering. Also, use lesd free solder. Lead based solder doesn't play nice with the lead free stuff they use on the boards.
If it's in a place outside the speedo, you can cut and splice out there. It's a lot safer and all you need is a little bit of shrink tube.
Fred_B is offline   Reply With Quote
Old 11-21-2009, 04:23 PM   #8230
LOW ET's Avatar
Trader Rating: 97 (100%+)
does the rs esc come with a sensor wire? if so, how long?
LOW ET is offline   Reply With Quote
Old 11-21-2009, 04:46 PM   #8231
20 SMOKE's Avatar
no wires come with motors
Jamie W
Old 11-21-2009, 05:43 PM   #8232
Geezatec's Avatar
RS/RSPro ESC does not include the sensor cable, But I believe its included with the Redline motors. They come with 100mm cable. TrinityDUO the cable is included. Cables are easy to find, 70mm- 225mm.
Geezatec is offline   Reply With Quote
Old 11-21-2009, 07:35 PM   #8233
Casey Belarde's Avatar
where do you get the 200 software at? or is it super secret
I have the latest hotwire 3.25 update but still no 200 to download to the esc
thanks for the info
Casey Belarde is offline   Reply With Quote
Old 11-21-2009, 08:09 PM   #8234
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
thanks for the info
A link was posted a page or so back.
The Original SC10 4X4 Clutch Basket
Steve McGeorge
Mac The Knife is offline   Reply With Quote
Old 11-21-2009, 08:18 PM   #8235
20 SMOKE's Avatar
yeah by me so here it is again
http://redirectingat.com/?id=42X1295...Hotwire200.zip
Jamie W
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
