Fukuyama Batteries
Old 11-09-2004, 07:20 AM
  #5941
John Fontaine's Avatar
Nope, I have a big racing coming up Sunday Nov 21st
John Fontaine is offline
Old 11-09-2004, 09:05 AM
  #5942
John Tag's Avatar
Trader Rating: 42 (100%+)
Welcome back John, Ill see you in 2 weeks
PS: Watch out now your gona hear it's ours not your's
Just listen to her with a smile it's all good once you get to the track.
John Tag is offline
Old 11-09-2004, 10:25 AM
  #5943
John, I want to try and make it this saturday, but things are a little hectic right now so it might be next weekend. How are the crouds for the sat night races? Good still? Thanks for the congratz. You might see the wife too since I might pull her along with me to the track every now and then.
Old 11-09-2004, 03:05 PM
  #5944
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Hi John
What are the best ways to storage the batteries? Or I shouldn't?
Will I be able to charge the batteries in the furture and without losing the performance? Thanks
PS Will the batteries go bad if I let it sit too long with no charge?
OVA is offline
Old 11-09-2004, 03:42 PM
  #5945
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Store the cells with 5.4v in the pack. If you're going to be storing them for more than a month, I'd pull them out every 3-4 weeks and cycle them once. When you start running them again you may need to put a cycle or two on them before they come back to full power again. But they should end up just fine.
Jon Kerr is offline
Old 11-09-2004, 03:45 PM
  #5946
JDXray's Avatar
Jon, you got pm
JDXray is offline
Old 11-09-2004, 03:55 PM
  #5947
OVA
OVA's Avatar
Thanks dude
OVA is offline
Old 11-09-2004, 04:19 PM
  #5948
Jon Kerr's Avatar
JD- back at ya
OVA - No problem. That's what we're here for.
Jon Kerr is offline
Old 11-10-2004, 05:11 AM
  #5949
Jon gives good advice!! It's exactly what I do except sometimes I forget to cycle them and it takes a little bit to bring them up to par
Old 11-10-2004, 06:39 AM
  #5950
What does it mean by store the batteries at 5.4V? How do u charge the batteries to 5.4V? After u charge the batteries full like at 5A, then discharge them til 5.4V ?
raceblast is offline
Old 11-10-2004, 07:39 AM
  #5951
Jon Kerr's Avatar
You need to put them on a discharger that has a 5.4v cutoff or one that can be adjusted to 5.4v. This is something you should have anyway to keep your cells at their best.
Jon Kerr is offline
Old 11-10-2004, 08:06 AM
  #5952
ok, 0.9V per cell
but then, I heard the cells should be charged to at least 2/3 of their capacity before storing them for long. Now, with .9V left in each cell, there is not much juice left in the cells.
Old 11-10-2004, 08:59 AM
  #5953
JDXray's Avatar
Originally posted by raceblast
ok, 0.9V per cell
I think if your leaving them for a long time you charge them up for like 1000secs and then store them i might be wrong someone should double check me.
Jon
JDXray is offline
Old 11-10-2004, 09:25 AM
  #5954
howard hudson's Avatar
another good tip is if you plan on putting away for a long time is to take off the battery bars. I heard that from the man himself
howard hudson is offline
Old 11-10-2004, 10:58 AM
  #5955
Jon Kerr's Avatar
The old 3000's you wanted to store with 2/3 to a full charge in them. But the newer cells will loose runtime and power if you do this. Howard also made a good point about taking bars off of the cells during long storage. This will keep them from drawing off each other.
Jon Kerr is offline
