Losi 1/8 8ight E 4wd Thread
#6106
#6110
How many classes do you run now a days
J/K You'll love the E bug, Its a whole new Animal.
#6111
Heres a quick dumb question....(Im new to 1/8 scale...give me a break!)
Will any 17mm wheel fit this buggy? I'm looking for a set of wheels for mine but none of the aftermarket wheels say anything about compatibility. Is "1/8 scale buggy wheel" exactly what it sounds like?
#6112
Yes, 17mm is pretty much standard for 1/8.
#6115
Hey guys, I need some help in the battery department. I have a RX8 1900Kv combo coming and I'd like to run a 5s battery. Run time goal is to get at least 15 minutes on an 1/8th track. 20 minutes would be even better as they sometimes do 15 minute mains. How many mah and what discharge rate would you recommend?
#6117
If you do decide to go the 5S route, you will need a smaller kv motor, no more than 1700kv.
#6118
Running a 1900kv on 5S, for racing, is a bad idea. Way way too much power. It will be uncontrollable. I can make a 15 min main easy with a 1900kv with a 5400 4S lipo. I did 20 a minute main with a 5600 lipo. If you drive smooth, gear properly and have a decent lipo you can run for a long time on 4S.
#6120
5S is a good way to go for lower temps and longer run times, but only if you run the right motor.
