NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 12-30-2010, 07:28 AM
  #2056
cuttingedge's Avatar
Originally Posted by Barry_Hughes
Except you do not list a 21.5 only the 13.5
They do But the only ones in stock are the 13.5 Baz thats why they are the only ones in the drop down menu ..
Having looked into it a bit more they may not be the best motor for me . awaiting an answer from HW on the power output
cuttingedge is offline
Old 12-30-2010, 07:52 AM
  #2057
WOW just tryed my Extream Stock out on the bench having upgraded to the is it 185 stock software and WOW it sounds faster than my Tekin RS Pro
And there is loads i can Put up on the power front i think as i have just put it all to the standard * marked settings ...............
Please let the weather change for Sunday
Old 12-30-2010, 01:08 PM
  #2058
What is the main difference between the 518STOCK and the 528STOCK?
Thanks.
february is offline
Old 12-30-2010, 05:45 PM
  #2059
I just bought the xtreme stock but Iam having a problem with it after about 3min or so it goes into I guess sensorless mode which makes it really slow! What do I need to do to fix it? Right now it is just setup with the preset settings?
trx B E is offline
Old 12-30-2010, 07:31 PM
  #2060
dameetz's Avatar
Thanks.
Difference that I noticed is start rpm can bet set to lower (3000) for 518 while the 528 can only go to 4500.
dameetz is offline
Old 12-30-2010, 07:36 PM
  #2061
dameetz's Avatar
Try lowering the voltage cut off to 3.0v.....My friend's xtreme stock had the same problem like you and solved it by doing that.
dameetz is offline
Old 12-30-2010, 11:21 PM
  #2062
Thanks. So the 518 is "better" than the 528?
february is offline
Old 12-30-2010, 11:57 PM
  #2063
COBRARACING's Avatar
You might have a voltage problem .Tell me what leds are lit when this happens ?
See all batterys are different and so are motors so you might have to change your low voltage cut off .
COBRARACING is offline
Old 12-30-2010, 11:59 PM
  #2064
Thanks.
528 is mod not stock 518 is stock 508 is no timing
Old 12-31-2010, 12:15 AM
  #2065
My fault I spoke about the 528STOCK from SP... I read very often that HW and SP are the same speedos, software etc... So I just need clarification.
Thanks for your time
Cobra: 1S works great
february is offline
Old 12-31-2010, 01:50 PM
  #2066
Same thing happened to me ... was using a 4000 mAh 30C Lipo and apparently it did not like the freezing temp of 0 degC. Changed the battery to a 5000 mAh at 40C and it was fine.
chinaman is offline
Old 12-31-2010, 04:26 PM
  #2067
The voltage cut off came setup at 3v? Should I lower it to 2.8v? Also I believe the led was flashing green but I will pay close attention when it happens again! Also I am using a 3000mah 40-50c but I dont think that should matter since the voltage was only at 7.7v?
trx B E is offline
Old 01-01-2011, 01:37 AM
  #2068
... Also I am using a 3000mah 40-50c but I dont think that should matter since the voltage was only at 7.7v?
Cobraracing also mentioned that batteries have an internal resistance and just did a quick read-up, and apparently with age, the internal resistance of a lipo battery increases.
chinaman is offline
Old 01-01-2011, 05:09 AM
  #2069
millbank's Avatar
where can i download the 185 stock software?
would really like to try this at the next big meeting in a couple of weeks and would like to test it before.
millbank is offline
Old 01-01-2011, 05:45 AM
  #2070
LOSI123's Avatar
Trader Rating: 63 (100%+)
can anyone email me hobbywing v1.5 Software?
Please pm me if you can, cheers
LOSI123 is offline
