New Yokomo TC, the BD-5
#1742
Front:
Tamiya Shocks with black pink HPI spring, 50wt oil, 2nd shock tower hole
1.4m roll bar
Inner steering block hole
8mm steering rack
5mm ride height, 6 Droop
1mm Shim under camber link in the bulkhead
HPI Pink spring
1 Toe Out
43.5 Toe blocks(front and rear)
Rear:
3 deg toe in
Tamiya TRF Shocks with black/blue HPI spring, 35wt oil, 2nd shock tower hole(counting from most inner one)
1.1mm roll bar
Inner hub hole
5.5mm ride height, 5 droop
Bd5w chassis with low diff position.
1.4m roll bar
8mm steering rack
HPI Pink spring
1 Toe Out
Rear:
3 deg toe in
1.1mm roll bar
Inner hub hole
If the problem still exists try 5.5, 4.5 droop.
Try Jordans setup as well
Antoni
#1743
Ahhhh yes i have blown his cover
How things ???
Dont no if you heard put SMA will be starting a Mod Class that will allow anything blow 10.5
And i know you do Alot of traveling So if you want to make a guest apperance now and then you are welcome
Just bring your car and batts i will look after the rest
How things ???
#1748
Does Roche sell a kit for it or do you have to buy it individual? Do you have a list of the bearings and the amont need? My instructions are in Japanese. I know Yokomo came out with a kit for the old BD (BD-BBC) and is still available. I'm thinking the bd5 and old bd uses the same bearing size so maybe i'll pick them up. Take care
#1752
no problem keefy any time
#1753
Ace poker, thank you at Elwyn and at Hobbyhaven staff... always fast and kindly.
Time to rebuild my car now
#1754
4 of them...WOW!!
#1755
