Old 05-20-2010, 02:24 AM   #1741
Send a message via Skype™ to JordanC
Originally Posted by defcone View Post
Because black shocks look really sexy and goes along with my black wiring, haha.
Do you want to try the setup I used at SMA keefy?
JordanC is offline   Reply With Quote
Old 05-20-2010, 02:40 AM   #1742
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Front:
Tamiya Shocks with black pink HPI spring, 50wt oil, 2nd shock tower hole
1.4m roll bar
Inner steering block hole
8mm steering rack
5mm ride height, 6 Droop
1mm Shim under camber link in the bulkhead
HPI Pink spring
1 Toe Out
43.5 Toe blocks(front and rear)
Rear:
3 deg toe in
Tamiya TRF Shocks with black/blue HPI spring, 35wt oil, 2nd shock tower hole(counting from most inner one)
1.1mm roll bar
Inner hub hole
5.5mm ride height, 5 droop
Bd5w chassis with low diff position.
TBO, i would use the Yokomo shocks as they work alot better for this car. Ok i see the problems. I would go Yokomo shocks with 500 wt oil, Pink Front silver rear spring. I would change the inner front camberlink to 2mm, and add 1mm shim to the inner and outer rear camberlink. Also stand up your rear shocks 1 hole and go 0.5d toe out on the front instead of 1. This should hopefully work.
If the problem still exists try 5.5, 4.5 droop.
Try Jordans setup as well
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 05-20-2010, 03:01 AM   #1743
Senna Racing's Avatar
Originally Posted by JordanC View Post
ahhhh got it.... Defcone is Keefy?
Ahhhh yes i have blown his cover
How things ???
Dont no if you heard put SMA will be starting a Mod Class that will allow anything blow 10.5
And i know you do Alot of traveling So if you want to make a guest apperance now and then you are welcome
Just bring your car and batts i will look after the rest
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 05-20-2010, 04:28 AM   #1744
Originally Posted by kschu View Post
Roche Carbon Steering Brace
Roche Spool & Ceramic Bearing
Roche carbon wing holder
I really want those new bits Hopefully next week. The bearings are fantastic, made my car super quiet...... Roche are making some great produts for the car
Antoni Caretti
Old 05-20-2010, 08:04 AM   #1745
defcone's Avatar
Trader Rating: 15 (100%+)
Nah, it only happens at Windsor.
defcone is offline   Reply With Quote
Old 05-20-2010, 08:45 AM   #1746
hotdognobun's Avatar
Trader Rating: 31 (100%+)
So anyone know if yokomo is going to start selling a ceramic bearing kit for this kit? Is the titanium coat suspension pins available yet from Roche?
hotdognobun is offline   Reply With Quote
Old 05-20-2010, 08:49 AM   #1747
Im not sure about bearings from Yokomo, but im using the Roche ones and im very happy with them. Also The suspention pins should be ready very soon, within a week i hope Ks will know more about this when they are ready
Antoni Caretti
Old 05-20-2010, 08:55 AM   #1748
Does Roche sell a kit for it or do you have to buy it individual? Do you have a list of the bearings and the amont need? My instructions are in Japanese. I know Yokomo came out with a kit for the old BD (BD-BBC) and is still available. I'm thinking the bd5 and old bd uses the same bearing size so maybe i'll pick them up. Take care
Old 05-20-2010, 09:04 AM   #1749
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Does Roche sell a kit for it or do you have to buy it individual? I know Yokomo came out with a kit for the old BD (BD-BBC) and is still available. I'm thinking the bd5 and old bd uses the same bearing size so maybe i'll pick them up. Take care
roche sell invidual size ....please visit KS HOBBY
size for bd5 is
5x10x4 = 4pairs
10x15x4 = 2 pairs
4x8x3 = 1 pairs
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-20-2010, 10:29 AM   #1750
size for bd5 is
5x10x4 = 4pairs
10x15x4 = 2 pairs
4x8x3 = 1 pairs
Very nice!! Thank you
Old 05-21-2010, 10:32 AM   #1751
defcone's Avatar
Thanks to all for the help, settled for yokomo shocks 500 wt oil front and rear and ran 5 front droop and 4 rear droop, as the droop gauges didnt have .5 increments and HPI pink and silver rears.
Qualified 2nd and got 3rd.
Old 05-21-2010, 10:41 AM   #1752
no problem keefy any time
Old 05-21-2010, 12:44 PM   #1753
altreyx's Avatar
Ace poker, thank you at Elwyn and at Hobbyhaven staff... always fast and kindly.
Time to rebuild my car now
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 05-21-2010, 01:30 PM   #1754
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
4 of them...WOW!!
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 05-21-2010, 02:10 PM   #1755
altreyx's Avatar
Originally Posted by fpart View Post
4 of them...WOW!!
They are for 4 people (1 is mine )...i'm a bad driver but not so bad to need 3 box of spare parts
Orca-Gm120
Reedy-Lrp
Helios EX10
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
