New Yokomo TC, the BD-5
#1726
Antoni
#1727
arcmen
#1728
The outer hole gives more high speed steering, I think this is because it gives the wheel a few more degrees of lock at full lock compared to the inner hole. The inner hole makes the car more twitchy and responsive, and the outer hole gives it better corner rotation. From what I have been testing, the inner hole is better for stock racing, and the outer hole is better for the faster classes were more steering is needed.
Antoni
Antoni
#1729
more droop in the front keefy
#1731
Are you coming in at low speed or high speed? Check to see if you have high drag breaks setting if you lift in the corners that will cause instanant weght tranferfer causing the rear to break lose, Also check the minor areas 1st like tire compund, camber, how much weight is in the front and rear, or maybe a simple wing adjustment will fix it. My BD5World does it at high turn-ins because my ball diff was tight in the front and was loose in the rear so it upset the back alot
#1732
#1733
you need to change your droop for windsor
#1737
Tamiya Shocks with black pink HPI spring, 50wt oil, 2nd shock tower hole
1.4m roll bar
Inner steering block hole
8mm steering rack
5mm ride height, 6 Droop
1mm Shim under camber link in the bulkhead
HPI Pink spring
1 Toe Out
43.5 Toe blocks(front and rear)
Rear:
3 deg toe in
Tamiya TRF Shocks with black/blue HPI spring, 35wt oil, 2nd shock tower hole(counting from most inner one)
1.1mm roll bar
Inner hub hole
5.5mm ride height, 5 droop
Bd5w chassis with low diff position.
#1738
Front:
1.4m roll bar
8mm steering rack
HPI Pink spring
1 Toe Out
Rear:
3 deg toe in
1.1mm roll bar
Inner hub hole
1.4m roll bar
8mm steering rack
HPI Pink spring
1 Toe Out
Rear:
3 deg toe in
1.1mm roll bar
Inner hub hole
