Team Much-More cell master v1
#1531
good day!!! anyone tried opening their cell masters? i'm having problems with my buttons some of them doesnt seem to respond well i would need to press down harder for them to work...
i'm thinking about cleaning them do you guys have any suggestions??? anyone having the same problems???
it would be very much appreciated thanks!!!
#1532
#1533
i had same problem... i had to push and hold for the button to work, when my one was new.
MM sugessted i try come contact cleaner spray. they are in your electrical store.
it works fine now
#1534
GymBeam thanks for the suggestion did you have any problems opening it??? any particular part/electronics i should avoid???
#1536
Will this charger charge the new Peak 3200 LiPo's ok?
#1537
For the Peak/Orion 3200, you should use a charger with at lease a 3A charging rate and 4.2V/cell cutoff.
By cutoff, I mean the highest voltage that the charger will allow the battery to achieve before reducing the charging rate to maintain that voltage.
#1538
#1540
Here is what I use, Charge Capacity 0000mha (the reason behind this is if you enter 4200 or whatever your batteries are they may and often do peak higher than that, with the value set at 0 they will naturaly peak, this also helps with getting rid of faulse peaks), I charge at 6 amps but it depends on how much time you have, I set the Delta Peak at 14 the book recomends 10 I go up a little to stop faulse peaks, Delay timer is up to you. Also I set the long lockout at 15min. Hope this helps, also here is a link to nexus racings
http://nexusracing.net/newsdesk_info...9039f7ec0e3a04
#1544
tx li-po charging question...
i'm currently using my ctx to charge my TX lipo battery... its a VXR 800mah 3 cell pack for M8/Stylus...
current CTX setting is set at 3-cell, charge current .8A... can i bump the charge current to 1.0A without damaging the pack? problem with the .8A current is that it just freakingly takes too long to charge my pack...
also, i've recently encountered temp cutoff problems when charging the TX pack... problem is i don't use the temp probe to charge lipo... seems to be a problem not only with my CTX (i have 2)... same problem comes up even when i try my friend's CTX.
Thanks!
Thanks!
#1545
Originally Posted by Casper
The cell master delta peak is for the pack. Most other chargers are per cell.
03 for most chargers is actually 18mv!
ex.
6cell = 03 >> 18mv as a pack
4cell = 03 >> 12mv as a pack
