Team Much-More cell master v1
#1547
At my LCD the letter D when discharging & letter C when charging at my cell master are slowly fading. what do you think is the cause?
#1548
Originally Posted by nikkiesteban
At my LCD the letter D when discharging & letter C when charging at my cell master is slowly fading. what do you think is the cause?
#1549
Originally Posted by Big B
Could be the is that the only one? What size power supply are you using? Has it been dropped or damaged at all?
#1551
i think someother lines in the LCD are slowly fading.
#1552
http://www.sparkfun.com/commerce/cat...s.php?cPath=76
I got hooked uuuuuup!
#1553
Originally Posted by m8commando
Are you guys having LCD problems.....I found replacement 16x2 LCD's.....3 different colors to choose from easy to change out......for $14.95 you can have a nice display and not have to deal with Much More customer service, the post office or time waiting and wondering when your much more product will be back to you, due to LCD problems! Check it out....
#1556
Here is what I use, I dont set any value the capacity (reason, most batts peak alot higher than the # on the side, by setting it at 0 they have a natural peak instead of stopping a at certain #) I set the amps between 5 and 7, Delta peak I set at 14, this setup works really well, I have never had a faulse peak with it.
#1557
I set my CTXC at:
6-8 A charge
47-51 temp cut - depends on ambient temp
5000mah capacity
21 peak detect - inside
14 peak detect - outside w/ heatsink
As for step, most tend to stay away from step charging with the new IB's, not 100% sure how it will work with EP cells. When I did use the step feature, I would use it a linear (all three steps the same) which allows the charger to use a very long lock out.
6-8 A charge
5000mah capacity
#1559
Originally Posted by Centerfire
A. Rhodes : Thanks! what do you mean 14 peak detect outside w/ heat sink? how will i set that?
Big B : THanks! How's the punch of the battery using 14 peak detect?
