Team Much-More cell master v1
#1651
Well, I can't answer the Fahrenheit question, but for the AA's, I wouldn't go any higher than 1A linear with a normal delta as they tend to false peak (most AAs are not designed for a fast charge), and at that rate you should be able to charge them in the tray with no concerns.
#1652
Are you guys having LCD problems.....I found replacement 16x2 LCD's.....3 different colors to choose from easy to change out......for $14.95 you can have a nice display and not have to deal with Much More customer service, the post office or time waiting and wondering when your much more product will be back to you, due to LCD problems! Check it out....
http://www.sparkfun.com/commerce/cat...s.php?cPath=76
I got hooked uuuuuup!
NICE info!!
#1653
does anyone know which voltage to choose from for the LCD replacement? i see 3.3V and 5V.
thanks
thanks
#1654
Has anyone been able to re-flash or update firmware on these to charge Lipo's at a decent rate ?
any-one played around with a eprom reader? and able to read the firmware off the silent charger???
I (like most people) have a couple of these gathering dust..
Just curious ...
Just curious ...
#1656
is this battery charger still very good? (not planing to use on Li-po for sometime now)
i planing to get a used cell master so what should i look out on the charger condition before buying a used cell master
#1657
not so much. the thing will only charge LI Ion at 1amp max. for a 4 cell charger it is great.
