Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 02-16-2006, 08:32 AM
  #3076
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Blue Sky
Is anyone using the aluminum upright 53687 with their stock suspension? I just got mine yesterday and found that the rear sway bar collars are rubbing the uprights.
Hi Ron
That Suck.... I'm pretty sure you will find the answer
OVA is offline
Old 02-16-2006, 08:33 AM
  #3077
OVA
OVA's Avatar
Hi Ron
That Sucks.... I'm pretty sure you will find the answer
OVA is offline
Old 02-16-2006, 08:51 PM
  #3078
rayman's Avatar
What gearing do you use for monster stock pro? I use the stock spur and 22 pinion but still feels too low and the car just doesn't have any top end. Doesn't tamiya make any smaller spur?
rayman is offline
Old 02-16-2006, 08:57 PM
  #3079
Slotmachine's Avatar
Does anyone know if the #50879 ta04 diff halves fit on the ta05?
Slotmachine is offline
Old 02-16-2006, 09:06 PM
  #3080
your gear is a 3.18 to1 I run a 3.48 to1 with a 100 foot straight You may be over geared.
Go Here and you can figure out your roll out in mm.`s with a 100 foot straight I am running a 25.4 mm. roll out. thats a 106 x 31 in 64 pitch......
Old 02-17-2006, 06:22 AM
  #3081
Regional Moderator
Darkseid's Avatar
Why worry about if Tamiya makes a smaller spur? Just go to standard 48 or 64pitch gears. Then you can go with whatever gearing you want.
Darkseid is offline
Old 02-17-2006, 06:35 AM
  #3082
work in progress...
Attached Thumbnails Tamiya TA05 Touring Sedan-p1010002.jpg   Tamiya TA05 Touring Sedan-p1010003.jpg   Tamiya TA05 Touring Sedan-p1010004.jpg
DA_cookie_monst is offline
Old 02-17-2006, 07:15 AM
  #3083
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by DA_cookie_monst
work in progress...
Is that the KAWAHARA chassis? I have the xenon CF and where the battery tape loops in the rear broke, I'm thinking of getting a new one, Its $90.00 bucks down the drain, BUT I can still use it just need to use the battery strap that came with it.
LMK what chassis and how it goes.
Attached Thumbnails Tamiya TA05 Touring Sedan-xenon-001.jpg   Tamiya TA05 Touring Sedan-xenon-002.jpg
cheehtae is offline
Old 02-17-2006, 07:20 AM
  #3084
Nope they don't.
GroffBall is offline
Old 02-17-2006, 07:43 AM
  #3085
axle182's Avatar
Trader Rating: 18 (100%+)
work in progress...
i like the look of this chassis what make is it? Keep us informed on how it goes. thanks
axle182 is offline
Old 02-17-2006, 07:54 AM
  #3086
cheehtae's Avatar
work in progress...
One thing--- where the motor mounts on (chassis), it's protruding. Would that be a potential problem?
cheehtae is offline
Old 02-17-2006, 08:37 AM
  #3087
It was an idea of myself, got someone from these boards to do the cad drawings (cause I can't) and then had them machined. The topdeck isn't quite right as yet and there is some misalignment on the chassis which is to be rectified on the next one. Will also be looking at making a better motor mount/bulkhead to, but one step at a time.
Old 02-17-2006, 08:39 AM
  #3088
Where do you mean, there is no underside protrusing.
Old 02-17-2006, 08:44 AM
  #3089
dodo's Avatar
seems to me that your idea is to substitute the 'endbell protector' with that protruding part. but IMHO that part will only scrap the asphalt when the car rolls. thus affecting the cornering.
dodo is offline
Old 02-17-2006, 08:47 AM
  #3090
cheehtae's Avatar
exactly
cheehtae is offline
