Like Tree4Likes
Tamiya TRF417
Old 07-11-2011, 02:06 AM
  #1711
FunkyDunky's Avatar
Guys are there any pictures about? would be really good to see what you are talking about
Cheers
FunkyDunky is offline
Old 07-11-2011, 02:45 AM
  #1712
barts71m's Avatar
Trader Rating: 34 (100%+)
Cheers
Check out Red RC ETS Gallery a few pages in now. Lots of pics of Marc's car
barts71m is offline
Old 07-11-2011, 04:26 AM
  #1713
Originally Posted by jonest
wonder whether they cut the rear part as well, as pic was blocked by the deans plug.
from ets Apeldoorn showing cut top deck at rear also.
Smartypants is offline
Old 07-11-2011, 04:47 AM
  #1714
TryHard's Avatar
I think it is. In the third picture (from the battery side) you can just see a slot cut... At least I think you can. Anyways, got a spare top deck to cut up and try now, let's see how it goes!
TryHard is offline
Old 07-11-2011, 04:57 AM
  #1715
FunkyDunky's Avatar
Originally Posted by barts71m
Think the are Roche outdrives, been released a week or 3 back. Very good ran them in my car last weekend for first time with 46mm driveshafts no wear and plenty of steering.
I agree they look Roche ones I have been running them for about a month now, I was expecting to kill the driveshaft pins but the are such a good fit there is very little play that could cause wear, would suggest this as am upgrade to anyone
Old 07-11-2011, 05:04 AM
  #1716
FunkyDunky's Avatar
Originally Posted by syndr0me
Motor screws are top/bottom on Marc's car with the 417 motor mount. We saw this at Reedy, too.
Hi could you please explain this I can't seem to see
Old 07-11-2011, 05:27 AM
  #1717
barts71m's Avatar
Motor in Marcs car is mounted top to bottom instead of side to side (kit setup)
barts71m is offline
Old 07-11-2011, 05:29 AM
  #1718
Could he be using a 416 motor mount instead?
Slick990 is offline
Old 07-11-2011, 05:31 AM
  #1719
FunkyDunky's Avatar
Great thanks I see what you mean now, I wasn't even looking at that! Must have had it machined out!
Old 07-11-2011, 11:23 AM
  #1720
jonest's Avatar
perhaps he could raise / lower the motor position by using this method.
jonest is offline
Old 07-11-2011, 03:27 PM
  #1721
hana166's Avatar
Raced on low traction, bumpy asphalt on Sunday...on 4th qualifier my car felt really, really good...when I got back to the pits I discovered I forgot to tighten the top deck screws after changing spur gear. 4 screws already had fallen out...car was the best I ever had it
hana166 is offline
Old 07-11-2011, 03:59 PM
  #1722
JimmyMac's Avatar
LoL, don't ya hate when that happens! But it's true, happened to me before. Makes ya wonder sometimes. Just dip the tip of the screw in thread lock, maybe they won't fall out next time..
JimmyMac is offline
Old 07-13-2011, 09:57 AM
  #1723
hana166's Avatar
Indeed, all that effort to fit everything perfect, remove tweak etc ..and its better not even screwed together
hana166 is offline
Old 07-16-2011, 11:09 AM
  #1724
kp-61's Avatar
is this the correct size for the wheel bearings ? I need to replace 8 of them
http://www.speedtechrc.com/store/ebp...id=961&id=9972
thanks !
kp-61 is offline
Old 07-16-2011, 05:32 PM
  #1725
Tron's Avatar
Trader Rating: 17 (100%+)
thanks !
You need the 5x10x4 for the bearings that are inside the c-hub and uprights...when you replace them don't lose the spacer that is in-between them inside the hub/upright.
http://www.speedtechrc.com/store/ebp...id=961&id=9964
Tron is offline
