Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 07-21-2010, 10:42 PM
  #3046
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by bl4
What is the Tamiya part no. For the soft short spring? Thks
http://www.rctech.net/forum/7525153-post2883.html
RedBullFiXX is offline
Old 07-22-2010, 05:20 AM
  #3047
oldnwise's Avatar
Default Wolf WR1 Manual
Manual for the Wolf WR1 is available on the Tamiya web site.
http://www.tamiya.com/japan/download...24wolf_wr1.pdf
oldnwise is offline
Old 07-22-2010, 07:03 AM
  #3048
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Can't wait to rock that vintage body.
j.d.roost is offline
Old 07-24-2010, 02:38 PM
  #3049
dsyed1's Avatar
anyone tried painting the stock f104 pro front and rear wing? would standard spray paint work? thanks!
dsyed1 is offline
Old 07-24-2010, 03:51 PM
  #3050
Andysan's Avatar
Hey are you the guy from PinionsandSpurs.com? If so your blog is cool, keep it up.
We use sticky vinyl for ours - is cheap, looks very professional, sticks well and doesnt come off, but if it does you can just apply more. Such an example can be found here.
On my Tamiya F102 (aka the F104 beater):
Andysan is offline
Old 07-24-2010, 04:44 PM
  #3051
aussierevo's Avatar
Trader Rating: 14 (100%+)
i've used the tamiya TS paints for the wings and very happy with how they turn out.
here is a Lotus T127 I did with painted wings.
http://www.rctech.net/forum/electric...ml#post7624394
of course, I think vinyl decal's are great as the paint will no doubt chip if used for racing. I have found a suppllier in the uk on ebay that has a great range of colours and they are really good quality.
I'm currently doing some more wings for another car, so when finished will post some pic's.
aussierevo is offline
Old 07-24-2010, 05:35 PM
  #3052
robk's Avatar
Trader Rating: 22 (100%+)
Lexan paint works fine since it has a flex additive and it also "bites" into the plastic more. I painted my Ferrari front wing and so far so good.
robk is offline
Old 07-24-2010, 09:52 PM
  #3053
dsyed1's Avatar
Andysan you are correct I do write that blog and thank you i am glad you found it usefull... great idea about the vinyl and the ps paint guys..
i have been working on a ferriar f60 body, will post pics thanks all
dsyed1 is offline
Old 07-25-2010, 04:09 AM
  #3054
Andysan's Avatar
That is very cool, where did you get the decals please? I've got a new paintjob on the way from a friend so will post it up soon.
Cant wait to see that. I recently switched to a TA05 and am currently running a spool up-front indoors. Even with 3 deg rear toe, shims under the upper camber link at the rear to raise the roll centre and a black rollbar up front only I cant seem to calm the rear end down. I'm running blue springs up front and yellows at the rear (reds dont seem to work, seem too soft) - any thoughts on how I can improve this setup please? Theres a load of setups here but these all seem to be for the opposite problem, not enough steering.
Andysan is offline
Old 07-25-2010, 10:25 AM
  #3055
Sauber F1's Avatar
I used to paint my front wings but I just could not find a paint that stuck. Vinyl comes in so many colors and the big advantage is, it can be re-applied if it looks beaten up.
Sauber F1 is offline
Old 07-25-2010, 01:43 PM
  #3056
cheehtae's Avatar
Trader Rating: 15 (100%+)
Need help here guys,
Just need a base line set up for carpet ( tight track) 21.5 for rubber and foams. All the help is appreciated.
cheehtae is offline
Old 07-25-2010, 02:03 PM
  #3057
aussierevo's Avatar
The decals for the Lotus are from D-Drive.
http://d-drivesportsenglish.com/inde...=index&cPath=8
Old 07-26-2010, 02:56 AM
  #3058
rc_square24's Avatar
How do you get rid of the spur gear play between the diff halves? It's wobbling when accelerating and i'm pretty sure its assembled correctly.
Or is it not much of a problem?
rc_square24 is offline
Old 07-26-2010, 05:43 AM
  #3059
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
It's not really a problem and perfectly normal. Well, that's the case with the Tamiya spurs. If you used a thinner one, it would wobble more, but unless it's extreme, it's not to worry about.
PDR is offline
Old 07-28-2010, 01:41 PM
  #3060
kmichael's Avatar
Quick question:I'm torn between 3racing 109 & F104 pro,really leaning to the pro because tamyia has been doing the F1 thing for quite some and would think more R&D,any help on this? The track is carpet.
kmichael is offline
