Team Losi JRXS
Old 11-01-2005, 12:05 PM
  #8716
Andrew Gray's Avatar
TCR- I cut about 2mm off the shock ends and nothing off the shaft
Andrew Gray is offline
Old 11-01-2005, 05:58 PM
  #8717
POOKYT's Avatar
I cut 1/8th inch of the shock ends per Todd and nothing off the shaft.
Who does that Numan guy think he is cutting the shaft! Pfffff!! LOL J/K
Brant
POOKYT is offline
Old 11-01-2005, 07:17 PM
  #8718
what does cutting the shock ends off do?
R/C Anonymous is offline
  #8719
Mike Haynes's Avatar
Allow the suspension to still go up far enough.
Mike Haynes is offline
Old 11-01-2005, 07:42 PM
  #8720
The JRXS editable set up sheet on jrxs.com isn't working. When you click on the link to it it takes you to some other non r/c website. Just thought I'd let you jrxs.com guys know.
The site should be up and running in two-three weeks
outlandr91 is offline
Old 11-01-2005, 08:02 PM
  #8721
POOKYT's Avatar
BADDA BING!!!!
Too funny!
Brant
POOKYT is offline
Old 11-01-2005, 08:23 PM
  #8722
Does anyone know what setup Chicky was running at the Halloween Classic? He was running the front motor car, right, in modified? Looks like he did well with it.
automator is offline
Old 11-01-2005, 10:19 PM
  #8723
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Andrew- If you didn't cut the shaft, then why is it sooo short?
J.Filipow is offline
Old 11-01-2005, 10:50 PM
  #8724
J.Filipow - As long as you cut the shock ends down a few mm it's fine, you need to trim them so you can have enough shock uptravel. I've never deemed it necessary to cut the shock shaft, plus that's just more work.
Old 11-01-2005, 11:27 PM
  #8725
POOKYT's Avatar
If you just trim the top off of the shock ends and expose a couple of threads, this will let the spring cup move lower so the spring will have more adjustability for ride height. Using the brackets (up and out on the arm) creates a shorter distance from the mounting hole to the shock tower hole. Hope this helps too.
Brant
POOKYT is offline
Old 11-01-2005, 11:29 PM
  #8726
POOKYT's Avatar
Has anybody else tried the front camber mod yet? If so what did you think?
Brant
POOKYT is offline
Old 11-01-2005, 11:42 PM
  #8727
Trader Rating: 16 (100%+)
Brant
Good description bro!
Hope you come to the 2006 Carpet or Asphalt Nationals kiddo!
Bill
Still Bill is offline
Old 11-02-2005, 02:27 AM
  #8728
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Brant
I've been running it for a couple racedays now, it helps out a lot on the front tire wear. I was running it with the low camber link mount on the shock tower, but went to the middle hole there, and also put .030 anti-dive in the car trying to get the turn-in to feel more like the stock link.
Randy Caster is offline
Old 11-02-2005, 03:40 AM
  #8729
Fatboy Joe's Avatar
Brant
Hi POOKYT,
Hi, I ws wondering if ya got pics of the mod in your car. Do y9ou still hook it up to the stock link locations in on the shock tower? Thanks
Sonny
Fatboy Joe is offline
Old 11-02-2005, 04:31 AM
  #8730
Brant
mines got the mod link on it...im racing tonight and will find out more
