Team Losi JRXS
#8717
Originally Posted by Andrew Gray
TCR- I cut about 2mm off the shock ends and nothing off the shaft
Who does that Numan guy think he is cutting the shaft! Pfffff!! LOL J/K
Brant
#8719
Allow the suspension to still go up far enough.
#8720
The JRXS editable set up sheet on jrxs.com isn't working. When you click on the link to it it takes you to some other non r/c website. Just thought I'd let you jrxs.com guys know.
#8721
Originally Posted by outlandr91
The site should be up and running in two-three weeks
Too funny!
Brant
#8722
Does anyone know what setup Chicky was running at the Halloween Classic? He was running the front motor car, right, in modified? Looks like he did well with it.
#8725
Originally Posted by J.Filipow
Andrew- If you didn't cut the shaft, then why is it sooo short?
Brant
#8726
Has anybody else tried the front camber mod yet? If so what did you think?
Brant
Brant
#8727
Originally Posted by POOKYT
If you just trim the top off of the shock ends and expose a couple of threads, this will let the spring cup move lower so the spring will have more adjustability for ride height. Using the brackets (up and out on the arm) creates a shorter distance from the mounting hole to the shock tower hole. Hope this helps too.
Brant
Brant
Hope you come to the 2006 Carpet or Asphalt Nationals kiddo!
Bill
#8728
R/C Tech Elite Member
Brant
Brant
#8729
Brant
Brant
Hi, I ws wondering if ya got pics of the mod in your car. Do y9ou still hook it up to the stock link locations in on the shock tower? Thanks
Sonny
