Ask Aaron Waldron
#1486
LOL..it's the old truck with a few of the new parts on it. I got my AD2 bodies and have already got them back from the painter, now just waiting on the truck...
#1487
A-dub are the new bods out yet, I need to get a few to skipgear.
#1488
Quick question, I am running a T3 and I am having problems getting it to turn in, it pushes real bad, to the point where I am loosing alot of time in every corner...
I am running proline edges and holeshots in the rear, green springs all around and 35 weight oil, I've tried all the possibly front shock position combos with no success, I have lower the front end and that did not help any either, could I change the battery position, could that help any, I would assume I would move them back so that more weight would be available to transfer forward, or am I wrong, anything else I could try, it I could get this thing to turn I would be golden....BTW: I am running a 19 turn motor and it is on a fairly hard packed surface, indoors....
#1489
Make sure your servo is up to snuff. Trying to get a truck to whip around corners with a poor servo isn't going to happen.
Moving your battery forward will definitely help. Check www.rc10.com for setup sheets for the T3, I'm sure they still have a few there.
#1491
Look on the brake rod. The collar in the back adjusts drag brake, the one in the front does full brake.
If it worked great out of the box, make sure your disc isn't glazed over; if so, rough it up with some sand paper or a hobby knife, or replace it (they will get worn and noticeably skinnier).
#1493
Aaron,Whenever the ad2 arrives will the parts be availible withit?
#1494
WO...I just had a great idea, although it would never work in racing situations, but it would be fun to try.... take a sheet of 1000 grit sandpaper the exact shape of the brake pad and glue it directly to the metal pad. Your car would stop like none-other, but the disk would wear out way before the 30 minute mark....the thought was there though!
#1497
TigeRyan - If I remember correctly, most of the AE guys ran softer springs in the rear of their T3's as opposed to the fronts. Softer springs often help the car find straightline traction.
#1498
TigeRyan, I'm not sure on the T3 but on my losi too much front toe-out caused it to push badly in the corners.
#1499
Thanks everyone for all the suggestions, have made a list of things to try, gotta get to the track early and try them one at a time and see if I can find some initial turn in....straightline the truck is real stable and fast, maybe one of the fastest on the track, but man does it stink around the 180's....if I get that dialed in I will be golden....
Again, I appreciate everyones help and suggestions, I will post how they worked out....
