Kyosho Ultima RB6 & RB6.6 Car Thread
for those running a front wing, what mounts are you using?
Sorry should say what wing mounts up correctly not seeing an option for the rb6.6 or rb6? Am I just missing it
Other way I ran it was by running a 4mm longer bottom shock tower screw (the one that mounts the tower to the bulkhead) and 4mm with of spacers. You then mount the wing in front of the tower, with the back of the wing screwed to it.
Anyone use the composite arms for the rb6? Thoughts? Worth it? What about the composite shock towers?
Thx
Thx
I run all composite parts in my second RB6 which I only use on carpet/astro. These parts are lighter and flex less so I have found that help the way the car handles on high traction surface.
They are also lighter so if you run stock you will lose a couple og grams too
How's the durability? This will be for med- high bite clay track.
Can I use the rb6 upgrades like exotek front shock tower And all Kyosho aluminum upgrades. ????
everything is the same... just a long chassis. Front end, zero change. rear end, zero change except laydown w/ FR suspension hold and option or 3 gear.
