Losi XXX-S
#828
sorry guys...i miss typed...the front end is dumping.....i am going to go to stiffer springs...all around....to see what happens....alsoi think a phone call to paul is in order....
#829
Mr. Losi....my front end was dumping too. It was giving me way too much front bite. I stood the front shock up one hole and it made a big difference.
#830
Front One-way
Anyone have a pic of the front one-way? It better be a nice looking and great working hop-up for the price Horizon wants for it!!!
#831
cannon, i tryed standing the shock up....it just made it more noticable.......i am going to stiffen the car up significantly...
what do you think, ron????
#832
Losi... Were you running 3 degree kickup? Try going to 0 on the car. I think more spring will help the car also. I have rebuilt my car with purple up front and blue in the rear hoping to have a one-way. If no one-way, I will probably go to even springs front and rear. I have a few other ideas also.
MK
MK
#833
Ran my XXX-S on carpet for the first time this weekend, it wasn't an easy time.
Ran purple springs all round, 80wt, 56F 55R for the first heat, on TRC Magenta rear and purple front tires. The car was too loose to drive. I wanted to run plaid front/purple rear tires, but the shop was out of plaids.
I went to the blue rear springs for the second round, also moved the rear camber rod from to the second hole out on the tower and the outer hole on the carrier. It helped, but hte car was still too unsettled to be consistent.
The track was tiny and bumpy, with six gigantic poles supporting the ceiling. There was ONE spot on the driver's stand where you could see the whole track, and I didn't get to it in time for any heats.
Third round I went to silver springs in back, the car got easier to drive but lap times were off.
Back to blue rear springs for the main, finished second in the A but 2 laps off the leaders pace.
NExt week I'm heading to a bigger smoother carpet track, I'm going to run Trinity Congo yellowF/purpleR springs, 80wt, 56F 55R, and I'll have the TRC plaids for the front and purps for the rear. Made the rear camber rod as long as possible too, inner hole in tower, outer in carrier. Stood both F and R shocks up to second hole from outside on tower. Hope it's better...
Trips
Trips
#834
Man, do I have alot to learn. I am just running the stock setup. And I think the car is dialed! I am running a P2K, Treadz foams, 37 rear/ 40 front. 4 mm ride height. Slammed Losi Stratus body, 2 droop in front, 3 droop in rear. And this car is stuck to the carpet, like glue! I can't get the car loose at all! This is my first TC ever. All though I don't have the batts like everyone else. I did place 4th in the "B" main. The mains went all the way down to "F", I think!
Oh yeah! That was my first TC race ever!
I am running very used matched 2400's!
Thanks Sir Speedy for the oneway part number! You da man!
#836
Anyone know of a aluminum screw kit for the XXX-S or a package for anothe car that will give me what I need for the aluminum screws for the XXX-S? I want to stay away from blue if possible I would hate to have , RED, SLIVER, BLUE and Purple stuff all in my car .
Mike Webb
Mike Webb
#837
mike
What happened to the Ti vendor that you were looking at?
#838
He was able to get only the shock tower screws for holding the shocks in the size I wanted to the spec of the kit. Everything else he could not get and didn't know where to get it. Also 4 screws were going to cost $9.50
#839
sam...0 kick and 2 caster...i ran it with black front and purple rear....car was good.....i am going to try and run the camber link longer in the rear..see what it does...what oil are you using??? i have 60 wt...
#840
Mike,
the TC3 aluminium screw set covers most of the XXXS screws, except the 4 longer countersunk screws that hold the kickup/antisquat thingies...
It's blue though
It's blue though
