Corally Assassin T/C
#31
Hey Pat
i am located in Sydney and got my pricing from "Dei Rossi Hobbies" campbell town Sydney
I am certinly getting the new Assassin as my current car is way past its useby
#32
Jeff, have you an available date for the corally assassin?
An aproximatif date?
#33
Ill bet he''ll tell you early june....
#34
#35
will be worth the wait i'm sure!
#36
Will the Assasin be avaible in Europe, specifically Denmark? If so, when?
I think that direct drive sounds very interesting - hopefully the direct feel, without the torque steer from a shaft drive car.
#37
Cole Trickle. Greetings from Malta.
You are close enough to drive across to Holland and buy one there, but I am sure you can buy a Corally in Denmark.
I agree, it certainly looks trick.
Regards
Joe from sunny Malta.
Regards
#38
Holland is close to me, however it'll be around 1-2 days. I'm not in the end of Denmark which is closest to Holland...
Anyway, Corally use to be represented in Denmark, but they aint very common.
A thought about the direct drive: Going from off-throttle to on-throttle, I think the car in the first few moments or so, will act like a rear-wheeler, because of the little time it takes to spool the belt up. In straight acceleration, I believe it's an advantage, but I'm not so sure, when it's about going out of the corners; Can it cause a little rear slide, until the front wheels come in action?
It's purely imagination, so comments are appreciated. Especially from people who have tried the Assasin on a track !
#40
Ray, The front and rear diffs are the same. All you would need to do is get the parts to make the rear diff. I will check and see if an optional diff package is possible. As you know they are working hard at building kits at this time. All of the Hop-Ups will come along a little behind the kits.
#41
Jeff
Is the car racing at the Reedy Race this week end??
If so which drivers will have it??
Cheers
Peter
#42
Hi Jantle,
When the ASSASSIN will be released?
Thanks.
Paul Yap
Thanks.
Paul Yap
#43
i have been thinking the same thing, i would think it would give split second of oversteer. Just think, you could be running wide on a corner so you give it some throttle! If you didnt like it like that(thats if it even happens) you could always run the dual belts.
#44
Paul, The kits are nearing completion. We are still waiting on a few parts from outside suppliers to complete them. Once all parts are received a better date can be released. The design is done and just waiting on these parts!
Tom, Cole Trickle, The new direct drive will suprise you! The large pulleys keep a lot of what you are talking about from happening. They transfer the power very well.
#45
Thanks Jeff.
Paul
Paul
