1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree2900Likes
Old 05-30-2014, 07:59 AM
  #10321
Cadman1981's Avatar
Originally Posted by ROB784
Hey guys, anyone here good at sourcing decals? I'm wanting to get my F113 to look like this.
Hakkinen's '97 Test MP4/13
Are you sure this is a test MP4/13? The car looks wider, and it's on goodyears!? Have any more info on this car?? Looks like a MP4/12.5 or something!
Cadman1981 is offline
Old 05-30-2014, 08:36 AM
  #10322
It's an MP4-12. It says so right on the nose. The last year of the wide track chassis.
viking44 is offline
Old 05-30-2014, 09:18 AM
  #10323
josecarlo1129's Avatar
Default Rear diffuser mounted for FGX
Rear diffuser installed. Tried all the available rear diffuser in the market and this one, (I reckon) is the perfect fit for 3Racing FGX F1.
Great weekend to all!
JC
josecarlo1129 is offline
Old 05-30-2014, 09:52 AM
  #10324
NutDriver's Avatar
Trader Rating: 30 (100%+)
I think R2 Hobbies (online and I believe out of Hong Kong) has West decals for sale.
NutDriver is offline
Old 05-30-2014, 10:17 AM
  #10325
Originally Posted by viking44
From the looks of that TRF101W front end, your ride height adjustment will be limited if the spring is between the upper arm and the upright. Unless you can shim the entire upper arm away from the aluminum.
But the kingpin looks like it can take the spring below the lower arm. If that's possible, then you can have more room between the upper and lower arms to position the upright for height adjustment.
It would be at max ride height as shown with no spacers under the upper arms. Adding the same size spacers under both the upper and lower arms will lower the ride height. So you should be able to get the right ride height for the tall Pardus tires. But you won't be able to raise it any more than it shows in the picture.
InspGadgt is offline
Old 05-30-2014, 11:40 AM
  #10326
Cadman1981's Avatar
Looks different from what i remember (and the pic on Wikipedia!), it changed a lot throughout the year 1997 i guess.
Old 05-30-2014, 12:10 PM
  #10327
vabroom's Avatar
JC
Which diffuser is it and where did you get it? thx
vabroom is offline
Old 05-30-2014, 02:46 PM
  #10328
Acid_CZ's Avatar
Originally Posted by Vyger
Hey guys, I recently got my paws on one of the new Tamiya TRF101w’s.
Hi. How is lower front arm mounted to the chassis? Can you take a picture of the lower deck from the bottom please?
Acid_CZ is offline
Old 05-30-2014, 03:32 PM
  #10329
It is bolted to the blue aluminum piece and servo mount which is then bolted to the chassis. You can see the screws and spacers used to bolt it to the aluminum piece and servo mount in the pics.
Old 05-30-2014, 04:18 PM
  #10330
Vyger's Avatar
Exactly what he said.
Vyger is offline
Old 05-30-2014, 08:48 PM
  #10331
Trader Rating: 11 (100%+)
From what I've read, it was a 12 but they used the 13 filtering testing. Not really too fussed, I just wanted an orange f1 car without it looking like a plain orange and black car. Just Googled orange f1 car and that's the closest one to the f113 shape. Only really been following f1 for the past 4 years.
ROB784 is offline
Old 05-31-2014, 11:29 AM
  #10332
Acid_CZ's Avatar
Thank you, this is why I asked. So F103 or F04 front can be used
Acid_CZ is offline
Old 05-31-2014, 01:38 PM
  #10333
I am now setting up my car f104 on carpet and found out SWEEP medium front and super soft rear works fine for me at the moment. I have a few questions.
I want to know if i use supersoft at the rear with a softer insert what happens, do I get more grip or will it be more stable? Because the insert in it now is pretty hard compared to RIDE tire i tried before which gave the car too much steering.
Also what happens with the car if use harder back tyres will I have more grip or will it be more stable.
I suppose if I use harder front tyres I get more understeer?
daang is offline
Old 05-31-2014, 06:00 PM
  #10334
the incubus's Avatar
Trader Rating: 17 (100%+)
Has anyone mated an F113 front end to the FGX Rear?
the incubus is offline
Old 05-31-2014, 07:20 PM
  #10335
emacrimes's Avatar
What are the best tires for untreated asphalt?
emacrimes is offline
