Secrets to RC
#31
#32
http://www3.towerhobbies.com/cgi-bin...&I=LXD712&P=ML
Mount tire on balancer and give it a light spin. As it slows you may see it starting to rock. As it stops it will probably be rocking back and forth. The harder it is rocking the more out of balance the tire is and the more weight you will add. You will add weight to the top of the tire now to offset the weight that is at the bottom of the tire. After adding weight re-spin and see what happens. You may need to add a lil more or take some off or maybe add a lil in an additional spot.
As for what to use there are a few options. You can get golf club weight tape and use it. Or you can get modeling clay. There is non hardening and hardening clay. Most people I've seen use the non hardening clay. You will stick either the tape or clay on the inside of the rim. If you use the clay make sure to keep it pretty flat on the inside of the rim. Also clean the spot where you plan on putting the weight with motor spray or something that will get off any oil and dirt.
Balancing tires makes a huge difference in the way your car will handle.
#33
#36
#38
#39
I bought a small tub (like a small Rubbermaid plastic container with a lid) and glued a scrub brush inside the bottom (bristles pointing up). At the track, I pour a little Simple Green in it, add water to just cover the brush, then use it to clean the tires. If you let them air dry between heats, the rubber gets a little tacky from the Simple Green.
#40
What I did was I took a old toothbrush and simply soaked it in water and scrubbed the tires and rims with it. Is that good and if I get simple green will it act like tire formula where the tire like stick to the ground?
#41
Simple Green does make the tires stick to each other pretty good. The rubber does get tacky, but I don't know if it makes them stick to the ground any better. I would imagine that if that were the case, any dust on the track would negate that after one revolution of the tire.
#42
#44
that's what I did, but we did testing years ago and found that any lanoin-based shampoo works better as it doesn't contain a degreaser like simplegreen does, which dries out the natural oils in the rubber, while just cleaning them returns the sought after like-new tacky feeling
#45
that not only sounds like a recipe for disaster, but also a good way to get your driveline out of balance
