Old 08-02-2008, 07:25 AM   #31
Suspended
Originally Posted by Stallard View Post
Yeah,
You have done a great job contributing to this thread
Are you so lame that you have to use another screen name to argue your point?
I'll make sure and note your fine contribution to the website gods.
rocket-mtrsprts is offline   Reply With Quote
Old 08-02-2008, 07:53 AM   #32
Trader Rating: 95 (99%+)
Originally Posted by Briguy View Post
So , how do you balance tires ? What weights do you use ? I have a prop balancer for balancing my boat props , so that should work for tires .
If you can get the prop balancer to hold your tire then yes it will work. If not get something like this:
http://www3.towerhobbies.com/cgi-bin...&I=LXD712&P=ML
Mount tire on balancer and give it a light spin. As it slows you may see it starting to rock. As it stops it will probably be rocking back and forth. The harder it is rocking the more out of balance the tire is and the more weight you will add. You will add weight to the top of the tire now to offset the weight that is at the bottom of the tire. After adding weight re-spin and see what happens. You may need to add a lil more or take some off or maybe add a lil in an additional spot.
As for what to use there are a few options. You can get golf club weight tape and use it. Or you can get modeling clay. There is non hardening and hardening clay. Most people I've seen use the non hardening clay. You will stick either the tape or clay on the inside of the rim. If you use the clay make sure to keep it pretty flat on the inside of the rim. Also clean the spot where you plan on putting the weight with motor spray or something that will get off any oil and dirt.
Balancing tires makes a huge difference in the way your car will handle.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 08-02-2008, 09:07 AM   #33
stitchy's Avatar
Originally Posted by 2MUCHSTUFF View Post
Before a race, turn each nipple 1/4 turn counter-clockwise - it really gets the blood flowing!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 08-02-2008, 07:12 PM   #34
Suspended
I find it really helpful to clean the tires when the tracks wet and leave them when the tracks dry...
B4 Racer1 is offline   Reply With Quote
Old 08-02-2008, 09:08 PM   #35
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Here's a good one and its really good to do with 1/8th scale but is good with electric to.
The steel pin held by a set screw with lock tight on a CVD..... Put JB-weld over the end and if the set screw backs out the pin will stay in.
UN4RACING is offline   Reply With Quote
Old 08-02-2008, 10:02 PM   #36
Regional Moderator
CarbonJoe's Avatar
Is it easy to get the JB-Weld out when you need to service the CVD?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 08-02-2008, 10:06 PM   #37
Suspended
for the b4 you can dremel the u brace down so the top is all even for more handeling..
Old 08-02-2008, 10:23 PM   #38
How do you clean the tires?
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 08-02-2008, 10:37 PM   #39
Regional Moderator
CarbonJoe's Avatar
I bought a small tub (like a small Rubbermaid plastic container with a lid) and glued a scrub brush inside the bottom (bristles pointing up). At the track, I pour a little Simple Green in it, add water to just cover the brush, then use it to clean the tires. If you let them air dry between heats, the rubber gets a little tacky from the Simple Green.
Old 08-02-2008, 10:45 PM   #40
What I did was I took a old toothbrush and simply soaked it in water and scrubbed the tires and rims with it. Is that good and if I get simple green will it act like tire formula where the tire like stick to the ground?
Old 08-02-2008, 10:52 PM   #41
Regional Moderator
CarbonJoe's Avatar
Simple Green does make the tires stick to each other pretty good. The rubber does get tacky, but I don't know if it makes them stick to the ground any better. I would imagine that if that were the case, any dust on the track would negate that after one revolution of the tire.
Old 08-03-2008, 06:51 AM   #42
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
That`s exactly what I do also . Except I bought this tub from Walmart that is sealed with an o-ring and just keep the simple green/water mix in it all times and just change it when I need to .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-03-2008, 07:59 AM   #43
UN4RACING's Avatar
You can file it off with no major trouble. I'm getting ready to do my 1/8th scale and I have it on mt T-4 as well, it works well if your running mod and 1/8th scale. Stock I think would be a waste of time.
Old 08-03-2008, 08:10 AM   #44
Suspended
that's what I did, but we did testing years ago and found that any lanoin-based shampoo works better as it doesn't contain a degreaser like simplegreen does, which dries out the natural oils in the rubber, while just cleaning them returns the sought after like-new tacky feeling
"the words cheap and fast should not be used in the same sentence"
oxymoron is offline   Reply With Quote
Old 08-03-2008, 08:13 AM   #45
Suspended
that not only sounds like a recipe for disaster, but also a good way to get your driveline out of balance
Speed Secrets (SS) RedEnzo Malaysian R/C Racers 197 09-21-2013 06:23 AM
Off-Road Tuning Secrets haulin79 Electric Off-Road 13 06-27-2008 09:30 PM
speed secrets?! any thoughts? streetracer745 Electric Off-Road 21 05-29-2007 11:51 AM
Racing Secrets!! Steve Charles Electric On-Road 68 11-22-2003 09:47 AM
