Secrets to RC
When practicing racing, try to be as smooth and consistent as possible. Don't just try to go fast and end up crashing every othre lap. Go as fast as you can without crashing and practice consistency, then go up from there.
Something like that?
....take your RTR apart, completely apart - and figure out and learn how everything works, where everthing goes, as well as considering that rountine maintenance (knocking the big hunks of dirt off doesn't count) is part of the hobby instead of it being an inconvenience and not waiting until it blows up or breaks to do anything......
Did you actually read the first post, or comprehend the idea of the thread, or are you once again doing the CP bit yourself -- that, by the way, you've got down pat!!!
Nice Try?
He seems to have it down pat!
Now back on topic,
One of the things I do that many overlook is balancing tires. It is easy to do and can make a big differance, also I always label my tires (RR,LR ect...), If you take off your tires for cleaning or maint. each run getting them out of order can affect handling. Nice idea for a thread B4.
1. Nothing is broken yet and you can see how everything is supposed to go together.
2. You can check and make sure everything is assembled correctly and TIGHTLY! This would have saved me a lot of headaches on my RC18T and on my TC4 (both suffered from steering slop and issues with the front driveshafts)
3. It forces you to see how the car SHOULD look after a run and gets you in the habit of checking that everything is nice and neat.
Play with spring rates and learn from experience. Read up as much as you can on electricity so you understand the difference between mah and ohm. Will make wiring alot easier in the end!
Get Deans connectors, on everything!
For the average RC enthusiast, learn Ohm's law like the back of your hand.
For a serious racer and setup fanatic I recommend learning F-Tests and T-Tests, just google it. If you have Microsoft Excel, it has built in functions to run the F-Test and T-Test for you.. These tests will let you know objectively if any change or changes you made truly made you faster or if you are just fooling yourself into believing others' or your own RC superstitions.
I have found that I am able to set up my car much better if I work on setting up my car on a big straight in a track. I have found that I can easily notice a difference in how fast I can drive a car while running tight circles. You will also be able to easily tell how much traction you are getting as well. While you tweak a setup be sure to take it off a jump every so often to make sure it is still flying well. I figure that if I can time 5 little circles & make sure the car has plenty of acel traction then I can dial the car in much faster then if I'm timing 5 laps.
I definitely second (or third) the idea of taking apart your RTR and seeing how all of the parts go together and work. In this way, you're going to be prepared if something breaks - you'll know how to get to the broken parts and replace them quicker, and you'll know what other nearby parts might have been damaged by the impact, which aren't as obvious.
Also on the RTR subject, get rid of the bullet connectors and direct solder as much stuff as you can, otherwise use Dean's plugs or the newer Traxxas hi-current connectors, whatever you prefer. The less resistance you introduce into the path of power in your car, the more juice you're going to get to the motor.
Great thread idea, I look forward to reading it as it grows!
