Hyper TT 4wd 1/10th Truggy Thread
#1561
They are actually for the Jammin SCRT-10 but they work on the lil guy....
http://www.amainhobbies.com/product_...ring-Bellcrank
#1562
Yes it will work, I have it on my Hyper 10SC which is the same steering parts as the TT. You just have to use the Hyper upper portion of the servo saver unit that connects to the steering servo. I also put the bearings in place of the bushings and it is silky smooth and bullet proof.
#1564
What other bodies fit these TT's? Anyone got pics of somthing else mounted on it?
#1566
Anyone know of an upgrade for the front steering knuckles?
Are there any aluminum ones out there or pending?
#1568
Yeah, I have been asking the same thing. The steering knuckles are crap. Spoke to ofna, they are working on something. IN the meantime, anyone else know of any other steering knuckle setup that will work, thats more durable?
#1569
Knucles are the plastic parts that are on the pivot balls,right?
I wish there was a C-Hub conversion for this truck....(Do anyone knows if there is one?If anyone knows even for Mini STe...they are the same)
#1570
I have a 10TT on the way, should be here Monday. I also got a MMP and Novac 4.5 from a guy on here to run in it. I read about 30 pages of this thread, but my eyes are getting tired, so I'm sorry if this has already been covered.
What gearing should I start with?
Is the 4.5 too much? Should I go with a 6.5 or something like that?
2s?
3s?
Let me know what you all think would be best. I also have a MMM with a 2200 motor I could always slap that thing in there. I like speed, but must also have torque for the triples with a short run at it.
2s?
3s?
#1571
I just recieved my replacement front knuckles, along with a spare set. Going to boil them to see if it helps at all.
I have not seen any replies from anyone stating that another vehicle's will work, so assuming there is nothing out there.
#1572
Anyone know the exact dimension for the width of the front lower arms on the Jammin scrt10? wondering of they will fit the TT. Looking for the width of the lower arm wear the hinge pin goes through. The outside width for part number 40836
#1573
#1574
Mod???
#1575
Even with the 54mm akerman bar, you still don't get as much steering as the mod I have posted for the Hyper 10 because the longer bar actually hits the posts, you need a V-bend in it to get the full steering radius out of it....Trust me, if my TT ends up running as good as my Hyper 10 with this mod, there's no catching it on a tight track...
