Kyosho v-one rrr
#7966
Location: Costa Del Sol, Marbella, Spain www.bradir.net
cars
toso's car.. / shimo's car.. as u can see, still the o'l same upper deck
PHOTO COPYRIGHT MIKE MYERS
#7967
RC_Alan
#7968
Originally Posted by rc_alan
Yes, they just changed the rear end to EVO specs...
RC_Alan
RC_Alan
#7969
evo
Originally Posted by rmdhawaii
Good catch Alan.
#7970
Other than ease of maintenance, there is no benefit.
#7971
"End play" is the amount of movement between the rear clutch bell bearing and the end of the threaded shaft just in front of the clutch nut.
#7972
the question what is better:
when the barycenter is more in the middle, like the new upperdeck or
when the barycenter is as deep as possible like the old upperdeck?
#7973
Barycenter? What do you mean?
#7974
schwerpunkt, isnt it the barycenter?
#7975
Hi Jaykay,
I had a look for the term and actually this is used in Astro-Physics for describing the centre of mass between planetary objects - I know the RRR is a star, but .....
But seriously, what you are refering to (schwerpunkt) is Centre-of-Gravity.
To my mind, the difference bettwen the lying and standing servo position is minimal and I doubt most people would be able to tell the difference.
The lying servo will have a lower c-o-g, but with the standing servo, the weight will be more central to the middle point of the chassis (should help for faster side-to-side transitions).
I have the Evo kit built into my RRR-WCE, but I left the original upperdeck to have the lying servo arrangement.
But I believe another advantage of the standing-servo is the direct linkage to the brake rod - probably the brakes work more efficeintly in this arrangement (aber wer bremst verliert )
I'm going to stick with the lying-servo arrangement, as I like the positioning of the receiver.
Cheers, Mark.
Cheers, Mark.
#7976
ahhh... center of gravity, that was the word i was searching.
#7977
Dear Team..
need Your set-up advice please...
I'm using RRR w/ Nova L5 run on medium track with 2 sweeper turn,running clockwise and medium traction..
Please give me the killer set-up, i'm runing front spool..
-F/R spring
-F/R shock oil
-Rear diff Oil
-Caster
-Camber
-F/R Toe
-Gearing
-Shock position
etc..
Thanks...
-F/R spring
-F/R shock oil
-Rear diff Oil
-Caster
-Camber
-F/R Toe
-Gearing
-Shock position
etc..
Thanks...
#7978
#7979
Originally Posted by spyspeed
Dear Team..
-F/R spring
-F/R shock oil
-Rear diff Oil
-Caster
-Camber
-F/R Toe
-Gearing
-Shock position
etc..
Thanks...
-F/R spring
-F/R shock oil
-Rear diff Oil
-Caster
-Camber
-F/R Toe
-Gearing
-Shock position
etc..
Thanks...
-F/R spring Blacks
-F/R shock oil 600
-Rear diff Oil 30-50000
-Caster stock
-Camber 2.5 front 3.5 rear
-F/R Toe f-1 deg. out r-2 deg. in
-Gearing 1st 16/61 2nd 21/56
-Shock position 1 hole up front 2 hole up rear
Hope thi s helps
Robert Maestrey
#7980
car
