Serpent 733 1/10 200mm touring
#2086
If you are using the stock black or orange belt they go loose in few meets time . I was told to use wider belt made by team titan or you can use X ray front belt . last longer and fits better . we will be trying some new belts this Sunday . will let you know how we go .
#2087
Hi W .T.
I am using the orange belt on the rear.
(During the A final it came off put it back on and finished the race)
New fot the final.
Let me know how you go.
Toaster
#2089
http://www.serpent.com/product/804192
#2090
ccrc is right, the belts go loose after the first runs...front and side belts also affected.
seems like the belts become slightly longer after they're been used.
usually i'll start with the stock tension for new belts and after a run, i'll adjust them a notch tighter.
#2091
I've been told that the new rear chassis brace fixes that problem.
#2092
I will give one a try.
#2093
#2094
why not try the old G4S underside belt tensioner, as i guess it would be easier to put on, and any added weight is as low as it can go. ? just a suggestion.
you can also then use the lowest position for the diff and even keep the weight lower there as well.
BTW
i dont have any problems with belts coming off, or getting loose. and i use the orange belts.
#2095
the underside of the belt is what gets loose, as that is the slack side.
Will look into it
BTW
Will look into it
BTW
