Old 03-18-2010, 05:42 AM   #2086
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Originally Posted by Toaster View Post
Has anyone had any issues with the Rear Belt Tension?
- Chassis is straight
- Cam is as tight as it goes.
- Pulley 20
Toaster
Hi W .T.
If you are using the stock black or orange belt they go loose in few meets time . I was told to use wider belt made by team titan or you can use X ray front belt . last longer and fits better . we will be trying some new belts this Sunday . will let you know how we go .
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 03-18-2010, 05:55 AM   #2087
Toaster's Avatar
Originally Posted by ccrcraceway View Post
Hi W .T.
Hi Alex
I am using the orange belt on the rear.
(During the A final it came off put it back on and finished the race)
New fot the final.
Let me know how you go.
Toaster
Futuba 4PK, CAPRICORN C02 , TITAN TOOLS,MRCCR
Toaster is offline   Reply With Quote
Old 03-18-2010, 03:17 PM   #2088
Trader Rating: 31 (100%+)
Originally Posted by Novarossi View Post
I added 1mm shims to each of the 3 screws that mount the middle hub, this allows the belt to clear the steering post as it shifts the whole assembly slightly to the right (when looking front on at the car)
Can you post a picture please?
Thanks,
Scott
1968 Camaro: 1:1, 5.3L LM7, Complete Restoration in Progress
SC10 Brushless
RC10B64 Club Racer
sdphilips is offline   Reply With Quote
Old 03-18-2010, 04:48 PM   #2089
YR4Dude's Avatar
Trader Rating: 44 (100%+)
- Pulley 20
Toaster
I've been told that the new rear chassis brace fixes that problem.
http://www.serpent.com/product/804192
YR4Dude is offline   Reply With Quote
Old 03-18-2010, 06:05 PM   #2090
keavze's Avatar
ccrc is right, the belts go loose after the first runs...front and side belts also affected.
seems like the belts become slightly longer after they're been used.
usually i'll start with the stock tension for new belts and after a run, i'll adjust them a notch tighter.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 03-18-2010, 06:21 PM   #2091
We will be trying this next weekend as i think that might be a solution , if not we will be getting more tension groves cut in the diff holder. or work out a pulley tension system , my drawing is crap but item might be good .
Serpent 733 1/10 200mm touring-imagetry.php.jpg
Old 03-18-2010, 06:25 PM   #2092
Toaster's Avatar
Thanks,
I will give one a try.
Old 03-19-2010, 12:45 AM   #2093
serpent is coming out the wider belt
http://www.rc-toro.com/product_info....8ce984f292d324
silverM3 is offline   Reply With Quote
Old 03-19-2010, 04:31 AM   #2094
Pattojnr's Avatar
Trader Rating: 19 (100%+)
the underside of the belt is what gets loose, as that is the slack side.
why not try the old G4S underside belt tensioner, as i guess it would be easier to put on, and any added weight is as low as it can go. ? just a suggestion.
you can also then use the lowest position for the diff and even keep the weight lower there as well.
BTW
i dont have any problems with belts coming off, or getting loose. and i use the orange belts.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-19-2010, 06:54 AM   #2095
Will look into it
BTW
Not driving hard enough . i could use couple of rear orange belts in the front . that how far they are stretched . But on the other hand both times this happened was on small tech. tracks . on and off gas too often .
Old 03-19-2010, 07:19 AM   #2096
Pattojnr's Avatar
well i was going to say that, but thats not the case unfortunately.
i have the same set of belts and pinions and spurs from the Nats.
Serpent - Walter RC
Old 03-19-2010, 08:50 AM   #2097
nitrodude's Avatar
Thats not where it goes, it goes between the motor mount and the bulkhead, inbetween the belt. The motormount side is screwd from the bottom of the chassis.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-19-2010, 08:54 AM   #2098
Here is a picture of where it goes.
Scott
Serpent 733 1/10 200mm touring-733chassisbrace.jpg
SC10 Brushless
RC10B64 Club Racer
Old 03-19-2010, 12:07 PM   #2099
OLDSKL's Avatar
I remember back in the day, I always wanted a Serpent with a RB motor...I couldnt give up the Mugen though
OLDSKL is offline   Reply With Quote
Old 03-19-2010, 02:07 PM   #2100
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
