TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-25-2012, 08:57 AM
  #1531
vito's Avatar
ok guys dose the body mount holes come cut out. on the 22 buggy they had to be made.
vito is offline
Old 08-25-2012, 09:16 AM
  #1532
Originally Posted by Quad Racer 34
I raced mine for the first time last night. I just put the kit setup on it with 30wt in the rear shocks rather than 27.5. This truck is hands down the best SCT I've ever driven. Turns on a dime and has great traction, lots of corner speed. I am very happy with this truck. And surprisingly, it's really light.
what tire setup did you use?
what compounds f/r?
med grip/loose outdoor track right?
gen3busonoma is offline
Old 08-25-2012, 09:18 AM
  #1533
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
They don't, since the mid and rear motor setups use different hole locations in the rear.
Frank Root is offline
Old 08-25-2012, 09:22 AM
  #1534
vito's Avatar
thanks is there marks?
vito is offline
Old 08-25-2012, 09:24 AM
  #1535
Trader Rating: 60 (100%+)
there are marks and a paper telling you which to use for the 22sct,xxx-sct, and the scte very nice.
motobigalow is offline
  #1536
jammnjeff's Avatar
Trader Rating: 143 (100%+)
am going to use the 20-25 kick do I jave to use the front hinge pin brace from the 22 ?
http://www.tlracing.com/Search/Defau...earchTerm=1051
http://www.tlracing.com/Search/Defau...earchTerm=1065
jammnjeff is offline
Old 08-25-2012, 09:44 AM
  #1537
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Does 18/86 for 7.5 and 20/86 for 8.5 sound Right?
RC*PHREAK is offline
Old 08-25-2012, 10:00 AM
  #1538
Trader Rating: 36 (100%+)
Yes, the 22sct has the kick built in (no shims). If you want less then 30° kick you must use the 22 front hinge and the shims to come with it.
To bad they don't have a shim that you could reverse to take a little of the 30° kick out
thefatkid is offline
Old 08-25-2012, 10:31 AM
  #1539
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
In the ball park. I was running 18/86 with a 6.5. The motor came off the track at 140 with that gearing.
Quad Racer 34 is offline
Old 08-25-2012, 10:33 AM
  #1540
what compounds f/r?
I wasn't planning on running it and didn't have any sct tires so a buddy let me use pink megabites for the front and pink megagrids for the rear. Med. grip loamy outdoor track.
Old 08-25-2012, 11:10 AM
  #1541
TLRacing
Mike Mellin's Avatar
You can actually use either the 22 or 22T/SCT front hinge pin brace. Both will work just fine.
Mike Mellin is offline
Old 08-25-2012, 11:19 AM
  #1542
jammnjeff's Avatar
ok thanks thought it might be different cause its stamped 30 degree I ordered the 22 one so I have a extra now
Old 08-25-2012, 12:32 PM
  #1543
RShockley's Avatar
Got mine built last night and looking forward to getting some practice with it after racing today. Decided not to race the truck until I had some run time on it.
RShockley is offline
Old 08-25-2012, 01:13 PM
  #1544
Trader Rating: 11 (100%+)
Originally Posted by Mototech
Anybody know if a Spektrum S6040 requires an extension wire in rear motor? Thanks
Anyone? Mine should be here Wednesday and I'm trying to get a final list together so I don't have to make multiple trips to the LHS.
Mototech is offline
Old 08-25-2012, 01:24 PM
  #1545
jammnjeff's Avatar
mine comes wed to rx goes right behind servo i think so shorter wire should work
