Hyper TT 4wd 1/10th Truggy Thread >
Like Tree48Likes
Old 01-18-2011, 02:58 PM
  #1741
jrz93's Avatar
Originally Posted by slowslug
The TT is not for bashing IMO
+1 it's a race vehicle no doubt if u want to bash get a traxxas
jrz93 is offline
Old 01-18-2011, 03:00 PM
  #1742
Originally Posted by 1Fastpede
if its a 540 can the RsPro is fine, The RsPro likes to thermal on the 550 motors.
Tekin recommends a RX8 for the 550 motors.
OK but can the RX8 handle 540 sized motors ok without any loss in performance compared to the RS Pro? I only ask because I plan to get into 1/8th scale as soon as I can and plan to run RX8's so I would rather stick with one kind of ESC if I can.
Also what are the sizes of a 540 and 550 motor? Most of the motors I look at dont state 540 or 550. Thanks for the info guys!
Lason is offline
Old 01-18-2011, 03:09 PM
  #1743
jrz93's Avatar
550 is basically the same diameter of a 540 just longer the 1/8 scale motors ie castle 1515,1517 and tekin 1/8 motors are bigger in both diameter and length
people with a rx8 at my track run it with either a 550 novak ballistic or 550tekin sc motor....regardless of what motor u get u will have to get another motor for an 1/8th scale.
i use a novak gtb and either a 550 or 540 motor the 550 runs A LOT!!! cooler idk what anyone says..550has more rpm tho so it's a choice/depends on what track u run issue.
the only negative issue is that the rx8 is real big for the tt..will not fit under the body unless you move the battery tray fwd and mount it behind the battery.
jrz93 is offline
Old 01-18-2011, 04:08 PM
  #1744
Originally Posted by NitroOB4You
DC- IMO, it is a very durable servo, and torque wise should be ok, but at .20, is very slow, especially if you're an experienced racer. If you're just bashing around it will serve you well or if you are used to "RTR" servos, I would say it would be comparable to those in speed.
how about this one?
http://www.savoxusa.com/Savox_SC1258...avsc1258tg.htm
DirtyCookieX is offline
Old 01-18-2011, 04:33 PM
  #1745
Trader Rating: 36 (100%+)
That is what I am currently using. After two race days, I'm very happy with it. It is noisy, but that's about the only drawback I've noted.
NitroOB4You is offline
Old 01-18-2011, 07:21 PM
  #1746
Dragula426's Avatar
The RX8 will handle anything motor wise you can throw at it. The only thing it will not do is add boost like the smaller RSpro which you should never need in a mod motor application.
Dragula426 is offline
Old 01-18-2011, 08:31 PM
  #1747
Cool, thanks for the info!
Lason is offline
Old 01-18-2011, 09:11 PM
  #1748
Slash65's Avatar
Questions?? Shocks?
Besides the Pro-Lines, has anyone found any good shocks that are a direct bolt on?
Slash65 is offline
Old 01-19-2011, 04:37 AM
  #1749
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Which Pro-Lines are direct bolt ons?
heavyjeffd is offline
Old 01-19-2011, 04:56 AM
  #1750
Why are people fixing things that are'nt broke?
Whosold is offline
Old 01-19-2011, 04:57 AM
  #1751
hyperdesigns's Avatar
hey guys just ordered my tt on monday. i already race a hyper 10sc so i know all the tricks and tips. but anyone running the castle sidewindersct combo? figure for a 100 bucks i would try it.
hyperdesigns is offline
Old 01-19-2011, 05:34 AM
  #1752
Cappy's Avatar
Trader Rating: 16 (100%+)
You mean like shaving A arms to get
more steering before acctually steering it
Cappy is offline
Old 01-19-2011, 06:19 AM
  #1753
The shocks are a definite weak spot i have stripped the threads on both front shock bodies, and the eclips come off inside the shock and then the piston is loose.
slowslug is offline
Old 01-19-2011, 07:49 AM
  #1754
I have had the complete opposite experience with my TT's shocks. I thought they were really high quality and have not skipped a beat yet. I wouldnt spend a dime to replace the stock shocks personally..... they are good enough as is IMHO.
Fleshgearf150 is offline
Old 01-19-2011, 08:10 AM
  #1755
That was Craigs fault.
Whosold is offline
