Xray T1FK05
#4833
new to xray
I just received my fk05 in the mail does anyone have good setup sheet for bumpy meduim traction asphalt?
also where is a good place online to get parts for xray?
thanks
Joe
thanks
Joe
#4837
Originally Posted by Nexus
PRS Spurs.
I bought a PRS 116 Spur thinking it would fit with no problems...
When mounted it rubs the motor mount. Has anyone else had this happen??
You still have my springs, right? Just make sure Rookie doesn't borrow them.
#4838
Originally Posted by kidDynomite
Nexus, I had this prob before when the car first came out. I took a sharpie to the motor mount and traced out the spur. Then took it to the bench grinder and shaved it a hair.
I did the same thing, but used a die grinder instead of a bench grinder
#4839
Trader Rating: 50 (100%+)
PRS Spurs.
Try to measure your sideplay on your layshaft...to see if there is something wrong with your bearing retainers, or layshaft bearings.
Also....try using RW spur gears, I believe they have them @ IRP.
I hope this helps Nexus.
Best Regards
Alex Cortez
#4840
Alex, good job at the Hurricane race!
#4841
It "truly" is a PRS gear I bought from IRP.
It still rubs...I guess maybe I can sand down the inner portion of the spur or something.
Hell I'll just keep running 48P!! It's easy to set mesh LOL :P
KidDyn...I have your springs and will try to catch up with you this weekend. If not I'll mail them to you or something.
#4842
Best Regards
Alex Cortez
#4843
Perhaps they may have changed the mold.....made it a wider in width????
Also try the RW Gears!!
Alex
#4844
No worry's about the springs. We'll see each other. It's not likey my cop friends are going to rip me off or something. BUT... if I don't see you before your baby comes... then yes, please mail them.
#4845
Does anyone run the 3mm chassis with IB3800s?
Does the battery slots need to be shaved more to compensate?
Does anyone know where I can get a good deal on a new or slightly used 3mm? Thanks!
