Xray T1FK05
#4681
Looking for some FOAM tires for 19T indoor carpet....and between PARMA and JACO, what shores are using between these 2 brands for carpet..?
I used to use Purple front Pliade rear (parma) for carpet, but heard the other 2 shores (Cyan front Magenta rear) is the new setup for carpet...any input?
Then Jaco...never use them, but they are cheaper...what shore to use...? I know it must be some double THIS and double THAT....
I know I will have to try those GQ....but I don't have them in hand yet.
Thanks.......
Thanks.......
#4684
Originally Posted by kerry
solara
i have tested between the 2 tire brands both have good points, i found a more consistent tire in the jaco. a good combo for carpet is dbl. pink(rear) dbl. pink orange for the front. cut them down to 58mm and you will like them.
#4687
3x8 Thrusts are still on sale at www.axiommotors.com under "Specials", sale will be ending soon.
#4689
I have found the opposite with regard to the Jacos. They are much less consistant for me - they seems to wear more unevenly and I've had many more problems with them coming unglued from the rim.
I would pick up a set of both and see which you like better.
The Parmas are also offset which helps on the Xray as the Jaco tires will rub on the shock collars. When using Jacos I have to use an xacto knife, and with the tire spinning on the truer, cut off about 1mm of the inside of the tire.
Josh
Josh
#4690
I am in the process of building my FK05.....I am debating between using the spring steel diffs and the spring steel wheel axels over the stock parts.... I weighted the axels and the spring steel are 3.5gr heavier each one, and the spring steel diffs are also heavier than the duralumium counterparts...... What is the real advantage in using the spring steel parts, they are a lot heavier.... (more rotating mass) I can understand their durability but I doubt the duraluminum parts wear fast....
For stock and 19t I think is better to use the duraluminum parts because of their weight......what do you guys think?
#4691
#4692
the diffs are uneccessary but the hubs are worthwhile as mentioned in the previous post the aluminum one's mushroom and are a general nightmare.
#4693
Or ream it out to prevent bending your shafts during hard hits.
#4694
