Like Tree387Likes
JConcepts Thread
Old 06-01-2015, 11:45 AM
  #8416
Default 2015 xb4 body
Is there any jconcepts body that fits the 2015 xray xb4?
Freeski is offline
Old 06-01-2015, 03:32 PM
  #8417
Default AMS 6.0 Cullman AL
I would like to thank JConcepts for being at Ams 6.0 race! Hope everyone made it home with no issues. Hope to see you there next year!
Sizemore is offline
Old 06-01-2015, 05:49 PM
  #8418
Trader Rating: 440 (99%+)
Any plans to make a body for the Tekno et48?
MattP is offline
Old 06-01-2015, 07:57 PM
  #8419
1/4milecrazy's Avatar
Originally Posted by TORQUE ROD
I'm going to start racing 1/8 buggy soon. Can anybody here help me on
what tires ( tire compound/tread and inserts) to use in an indoor cool and tacky
clay tracks? Thanks in advance.
Dirt webs in green. That would be my choice. That is what I use on my tenth scale stuff for indoor. I am sure the 8th scale would be just as awesome. If it is super high bite then I would go blue.
1/4milecrazy is offline
Old 06-02-2015, 05:27 AM
  #8420
PW
PW's Avatar
What track is it? Depending on surface, I would think Dirt Webs or Bar Codes in gold with Dirt Tech inserts.
Not sure, maybe someone has tried a Silencer series for the B44 or Kyosho?
Not at the moment.
PW is offline
Old 06-04-2015, 01:16 PM
  #8421
The new bar fly tires look great. Do the bar flys fronts steer more aggressively than dirt web fronts? Also, are the rippit/whippit tires ever going to be available in gold compound?
RIchie-Peters is offline
Old 06-04-2015, 01:39 PM
  #8422
PW
PW's Avatar
They do seem to have a little more steering; the overall car feels like it's a little more free in the corners.
No plans for gold at the moment (rippits/whippits).
PW is offline
Old 06-04-2015, 01:45 PM
  #8423
Thanks for the quick reply PW. I might have to give the bar flys a try.
Old 06-13-2015, 09:30 AM
  #8424
mes
Is it too early to say if the Team Associated SC5M will run the +3 Hazard wheels #3344 or the #3352s?
mes is offline
Old 06-13-2015, 10:43 AM
  #8425
thecman26's Avatar
Trader Rating: 112 (100%+)
It has already been discussed, it is going to use zero offset wheels.
thecman26 is offline
Old 06-14-2015, 12:07 PM
  #8426
mes
Thumbs up
Thanks, did not find it using the search function!
mes is offline
Old 06-14-2015, 03:34 PM
  #8427
Default Stadium Truck Dirt Tech Foams
Foams included with dirt webs way too hard. Will have to cut tires and punch holes in foam. Have had success cutting right next to wheel. Planning on holes per every rib. Comments?
Micah123 is offline
Old 06-14-2015, 03:57 PM
  #8428
aeRayls's Avatar
If they came with the blue foam just run em. They soften up really quick and are great! If they came with the gray dirt techs, wash and dry em in a load of laundry and then run em. I haven't put holes in truck ones yet but if I did I'd do it just like the buggy foam. Turn em inside out and Put 2 or 3 holes in every inside rib!
aeRayls is offline
Old 06-14-2015, 06:13 PM
  #8429
They came with dirt techs. Previous set came with blue foams that worked fine but new dirt techs are way firm for stadium truck tires. Run at sdrc in san diego which has very good traction. thanks for the input. was planning on 1 hole per rib but will compare 1,2,and 3 before re gluing. thanks again.
Micah123 is offline
Old 06-14-2015, 07:24 PM
  #8430
Trader Rating: 32 (100%+)
need a small pin sc 4x4 tire between double dees and pressure points. Recommendations? Loamy, wet outdoor
Brandon Powell is offline
