Hot Bodies Cyclone
#3886
Originally Posted by AngryAsian
Thanks guys!! Much appreciated..
The hot bodies website is a bit vague on what the original has, and what the special ed.'s have as standard kit. I should have just looked at the Suri page and left it at that. They need to work on that website!!
I have to admit - i am a little hesitant to buy simply because i didn't have a great experience with belt maintenance on the old schumacher. How do the belts hold up in the cyclone? Especially running outdoors?
Other than that - it looks like the one for me..
#3887
Here are some pics of my new Surikarn Edition. I'm still waiting for the new blue anodized Pivot Blocks.
#3888
all i run is outdoor asphalt with a 4.5 brushless of a checkpoint 7x1.i have about 10 full race days on the car and the belts are still fine.i actually havent had to adjust the tention yet.
#3890
Super Moderator
Originally Posted by Marcos.J
I actually got a 110 64 pitch spur to fit with a little mod (very easy) this way you do not have to grind down any or if any parts in the motor mount. The spur sticks out maybe .015 past the chassis but it should be fine I dont think that the chassis will go completly falt to grind down the spur. Ill be testing it tomorow
the 110 spur worked great with no issues
#3892
Originally Posted by JoeyE
The belts are fine. I never had any problems running my Cyclone outdoors. I'll have to get another one
#3893
Originally Posted by KilRuf
Hey Joey, are those Square Tamiya shock collars on your car? I don't like the stock ones.
Those are HPI shock collars. They are just anodized TAMIYA blue. I anodized all the aluminum TAMIYA blue. A buddy up in Sacramento, CA has the car now
#3894
First night on my surikarn wasnt bad, I qualified 2nd in 19t. The car reacted well to changes. I pretty well ran a kit setup, with 40wt, the front rollcenter raised under the pivots, gold front ae springs and blue ae rear springs. I was having a problem with keeping the rear end planted. Any changes right off hand to try next time on a low bite surface?
#3895
Super Moderator
#3896
#3900
Super Moderator
I read you were running a 110 spur without problems, about what is the smallest you have ran?
