The Losi Mini 80808 Project >
Old 05-20-2013, 06:17 AM
  #46
Mini80808's Avatar
Originally Posted by Rac3rX
I have that batt and its low c rating gave me issues with HET 6000kv
Yeah they are crap IMO. I have had nothing but issues. I guess that is what you get for $22
Mini80808 is offline
Old 05-20-2013, 06:36 AM
  #47
It was good for the CM2646 & MMicroP but couldn't deal with 4pole & 6000kv demands. Probably the same for the 0808, its not handling the demands of 4pole burst.
Its pretty old and batts have gotten better since they were released, higher c batts are needed for the extreme systems pushing limits.
Its a bigger issue when pushing BB systems in a MERV small batts and high demand dont mesh well lol
Rac3rX is offline
Old 05-20-2013, 09:47 AM
  #48
Mini80808's Avatar
and then to top it off, the battery has to be tiny to fit in there. So like I said, ill probably just have to buy the Losi 3s.
Old 05-20-2013, 01:05 PM
  #49
Mini80808's Avatar
I can pick up a Zippy 1500mah 25c 3s lipo on Ebay for the $20. I think ill try it. What the hell right?
Old 05-20-2013, 01:28 PM
  #50
MajorKong's Avatar
Oh yeah!! For the last 2 months every Friday night we all meet @ my house and run our creations. Nitros, Crawlers, Funny cars etc. My battery of choice has been a Venom 2000 20c 2s lipo. Fully charged id get about 20-30 50 yard passes up my street. Car seemed to go faster with each run. Once the battery was done, id bring the car back inside, check everything out, re charge and back out she went.
No 3s yet. Cant find a small enough battery. Researching that now.
Thunder Power, TP1800-3SPF70, 1800mAh 3-Cell/3S 11.1V. It is the largest 3s lipo that will fit in the mini 8ight without modding the battery tray. 24mm tall, so the battery strap will not fit. No need for it since the battery touches the bottom of the top brace on the chassis. It isn't going any where. Down sides are that TP batteries use a non-standard balance connector that you have to get an adapter for. Dynamite sells an adapter. After I starting using this battery my spur gear stripped and pre mounted tires came unglued on speed runs.
http://thunderpowerrc.com/G8ProForce70C.htm
MajorKong is offline
Old 05-20-2013, 04:04 PM
  #51
Wow That's pretty SicK sure beats the 3s 30c and 2s 50c Ive been using instead of the 20c Venom pack. Ill have to grab some, not too worried about getting an adapter, adds to the "Trick" factor lol Ill have to check the battery box specs on my Mini Revo because those would be perfect for my Sensored Flux Pro 3.5T 8900kv Big Block Mini Revo
Rac3rX is offline
Old 05-22-2013, 10:20 PM
  #52
Mini80808's Avatar
Capacity: 4000Mah
Cells: 3S
Volts : 11.1V
Continuous discharge rate : 40C
Max discharge rate : 80C
Dimensions : 42 x 138 x 25mm
Weight : 304.5g
Max charging rate : 10C
Apply : for Helicopter Airplane
Whats the difference in car and plane batteries? Im gonna say nothing.
Old 05-22-2013, 10:35 PM
  #53
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
There is no difference except most car packs are hard cased not soft ....
BashemSmashem is offline
Old 03-14-2014, 06:02 PM
  #54
ODA
ODA's Avatar
We'll done, keep us updated plz, I will be doing the 0808 conversion
ODA is offline
Old 04-20-2014, 06:05 AM
  #55
Mini80808's Avatar
Default 8200
Getting ready to go all out!!! My 4100 is going in my Mini T Pro and an 8200 is going in the Mini 8
Stayed tuned!
Old 08-21-2014, 10:12 PM
  #56
What ever happend to this?
ironceltic12 is offline
Old 10-30-2014, 06:09 AM
  #57
Mini80808's Avatar
We are Back! New parts on the way!!!
Long story short, I relocated and my RCs had to wait :-(
