The Losi Mini 80808 Project
This thread is an informational thread for anyone interested in modifying thier existing Losi Mini 8 with a Castle Creations 0808 4 pole 4100 kv motor. I purchased a set from my LHS that came with Micro Sidewinder ESC for $89. I am looking to build a Mini 8 that is just designed for pavement and speed runs. With this configuration I will not be racing on dirt, clay or sand and no bashing what so ever. Just concrete and asphalt for flat out SPEED!!!!
CURRENT MODIFIED CONFIGURATION as of 4/28/2013 __________________________________________________ ______ Motor · Castle Creations 0808 4 pole 4100 kv motor · Robinson Racing 20t 48 pitch 2mm bore pinion gear ESC · Castle Creations Micro Sidewinder ESC Battery · Venom 2000 20C 2s Lipo Chassis · Tbone Bumper Everything else will be considered stock if it is not listed above. I want to provide the exact information on what my Mini 8 is running to aide in the creation of even better ones then mine. This is not a testosterone display but merely a source of information gathered from literally hundreds of hours spent here reading and designing something that I think we all will enjoy learning about and watching it run. More soon... |
I'd like to see your Time Machine. Start date 5/28/13?? We aren't even through April yet!
This thread is totally useless with pictures and or video.:nod:
Originally Posted by GrimReminder
(Post 12095423)
Admistrators? is this how lethal this place is? :sweat: |
I have been thinking about getting a 0808 motor, I can't wait to see the results. SUBCRIBED!!!
I got one in my m8, ran it a couple times threw the cm26 back in.
Originally Posted by Mini80808
(Post 12096386)
Really? is that all you can successfully contribute to this thread? First off im assuming, in your case individually, that you have ignorantly misspelled WITH in an *** spell reffering to WITHOUT. If you could see, let alone, read youd see I have 4 posts. Im sure being the slurp you are, you would know that I am still not qualified to post pictures, hence the more soon ending.
Admistrators? is this how lethal this place is? :sweat: Secondly I already told you that that speed controller isn't gonna work for you. You need the micro pro to do what you want it to do. That combo is for those little 1/18 scales. Call castle if you don't want to believe me, I've already been through this. Watch your mouth...:nod: |
I'm interested in the results, but could do without the profanity and personal attacks. How about taking a moment to edit them out?
20mm can seems a little small for a 1/14 scale. |
Originally Posted by YouSuckDude
(Post 12096579)
Originally Posted by txhookey
(Post 12097214)
(Post 12097236)
Trust me if could and knew how, I would Nothing annoys me more then some \** whos got nothing better to do then ruin it for everyone.
Come on guys , no need for the bickering ! Keep it up and the Mods will come in and close this thread :deathstar
Grim is right though threads like this are useless without pics and that Micro Sidewinder wont be enough unless you find some way to cool it down . Good luck ! |
It would be nice if you edited out your profanity on a total of 3 posts now. This is a kid friendly place. You can hit the edit button on your own posts and just space bar them out. Also the personal attacks, critiques or civil disagreements are OK, but name calling seems to cause problems. You can edit those out as well, chances are the mod is busy, it would be good if you edited it your self instead of waiting for him to drop a hammer on you.
Closing this one down. I cant post pics so its pointless. Well try again at a later date
(Post 12097230)
Why is that? And lets say a 2668 is a ten, what would a 0808 be?
Cm26 is just way more torque and speed man. 808 ran smooth powerband was more predictable and easier throttle control but for all out speed and bad assery 26mm can seems to be perfect for 1/14th scale |
