Kyosho Touring Car >
Kyosho Touring Car
Kyosho Touring Car
Old 10-26-2007, 06:57 PM
  #1606
Kropy's Avatar
Trader Rating: 12 (100%+)
Originally Posted by POOKYT
Holy Crap!!!!!
What do we have here??????
This thread has actually been on the main page for like 3 days now!!!!
Has anybody heard from Steve @ Speedtech when he thinks the Shin Edition or the conversion will be in the USA?? Glad to see you guys suing this thread again. BTW--Where O Where is Mr. Matt ????
Brant
Pook ~ Have you tried here yet?http://www.horizonhobby.com/Products...rodID=LOSK0256
Kropy is offline
Old 10-26-2007, 07:05 PM
  #1607
Scrad's Avatar
Trader Rating: 16 (100%+)
When I ordered some stuff from Speedtech last week they told me it would be soon. Probably on the next Kyosho order.
Scrad is offline
Old 10-26-2007, 09:46 PM
  #1608
SQC049's Avatar
Trader Rating: 18 (95%+)
Originally Posted by Scrad
sqc049-Check the for sale section. There is a NIB stallion for $300. The seller is mrcer4life or something like that.
Sweet, thanks man! I just contacted the seller.
SQC049 is offline
Old 10-27-2007, 10:12 AM
  #1609
M@t
Default Kyosho parts
A few weeks ago à turned from Xray to Kyosho, and I realised how difficult it's to find stallion parts.
For me the best ways are :
1 - rcchamp ([email protected]) (they made special order to Kyosho for me)
2 - www.speedtechrc.com (don't have all the part number, but they are serious)
3 - www.rc-direct.co.uk (didn't try but have some shin editions parts)
4 - www.tqracing.se (didn't try but have some shin editions parts)
Never order to Racing11 (http://www.racing11.net/) I never recieved my parts, and had to require a refund.
M@t is offline
Old 10-27-2007, 09:01 PM
  #1610
Trader Rating: 14 (100%+)
I picked up a stallion today. Can some post a asphalt rubber tire setup for me.
Thanks,
Joe
Joe Maxey is offline
Old 10-27-2007, 10:40 PM
  #1611
POOKYT's Avatar
Originally Posted by Kropy
Yup! I tired that one!!! LMAO
Its just a bit hard to stay on board when the Capt. and crew start jumping ship! LOL
Brant
POOKYT is offline
Old 10-27-2007, 10:47 PM
  #1612
Trader Rating: 40 (100%+)
maxey sent you a pm with a setup
King of B Main is offline
Old 10-28-2007, 03:30 AM
  #1613
I)arkness's Avatar
hey guys, its good to see some action in the kyosho section, would anyone have a rubber setup for the shin edition for a technical tarmac track
I)arkness is offline
Old 10-28-2007, 07:32 AM
  #1614
Thanks King.
Old 10-28-2007, 05:48 PM
  #1615
Guys here is Derek Furantani setup for High bite to medium bite asphalt...Great starting point , and pretty sure it will work for the shin car. I have used this setup for stock, and 19 turn brushless...
Front of Car
Spool or One way with AA diffs
Front block CCin , 2 mm spacer in front hidge pin, #3 spacer underneath blk
Rear block CCin , 1 mm spacer in rear hidge pin, #3 spacer underneath blk
Droop 5 with yokomo gauge
Camber 1.5 to 2 degree camber you choose, toe 0 to .5
Stock 3 hole pistons, 45wt kyosho oil, blue kyosho spring(I use Tamiya gray)
2 mm spacer in Front top camberlink, use the back camber link hole
Shock position 2nd hole from bottom
Rear of Car
Front block BBin, 2 mm spacer in front hidge pin, #3 spacer underneath blk
Rear block DD out, 1 mm spacer in rear hidge pin, #3 spacer underneath blk
Droop 4 with yokomo gauge
Camber 2 ( I look at ware of tire, I usely use 1 degree)
1 mm spacer in rear top camberlink in far back hole
stock 3 hole pistons, 40wt kyosho oil, orange kyosho spring(I use tamiya blue)
Total 3 degree toe
Shock position in middle of shock tower
AA rear diffs
We use Mazda 6 or Mazda speed 6 bodies
Tires RP30 out door or Sorex 36 with yokomo thin insert at Socal
Hopefully this will be a good starting point and I did not forget anything..
Old 10-29-2007, 12:07 PM
  #1616
All I have is Kyosho 400wt oil is there any other manufactures oil I could use that is close to 45wt kyosho oil. I have X-ray, AE, Losi.
Miny thanks,
Joe
Old 10-29-2007, 04:54 PM
  #1617
SQC049's Avatar
Does anyone have a setup for a Stallion, foam on carpet? I'm picking one up.
SQC049 is offline
Old 10-29-2007, 06:14 PM
  #1618
SpeedTech's Avatar
Hi Guys,
We're fully stocked with Kyosho parts again.
Jeff
SpeedTech is offline
Old 10-29-2007, 06:38 PM
  #1619
Have a try here, middle of the page, there is something about the Stallion!
http://www.petitrc.com/view_news.php?id=4622
Arn0 is offline
Old 10-29-2007, 07:32 PM
  #1620
Originally Posted by SpeedTech
Thanks Jeff!!!! I just made a order.
Thanks,
Joe Maxey
