Tamiya TRF418
#1096
Reedy Race 13.5 Setup
Hi All,
Attached is the setup I used on Saturday, when traction was extremely high. Please note, I included references that specify which ball studs were used. Additionally, this works with either a ball or gear differential, depending on how much you enjoy wrenching and your driving style. I'm lazy and ham-fisted so I used a ball diff
#1098
ORCA VXX
Keith Yu provided some excellent baseline settings. The following is what I used:
R1 Wurks 13.5T
- Running Mode: Fwd/Brake
- Battery: Lipo
- Cut off Voltage: 0.3 (basically off)
- Over Heat: Off
- Neutral Range: 6%
- Blinky Mode
- Drag Brake: Off
- Initial Brake: 6%
- Brake Freq: 1k
- Punch: Level 10
- PWM: 8K
R1 Wurks 13.5T
- Timing: 38
- Spur: Panaracer 102
- Pinion: Xenon 46
- Ratio: 4.10
#1099
#1102
so might as well wait for the 418X...
#1103
From what I have seen and heard the chassis is very similar, maybe the chassis is less stiff? Jill's car looks the same as mine other than he is a better driver
#1105
In my opinion, don't see anything really wrong with the current chassis in Spec racing, so waiting for the 418X is probably only advantageous for Mod class mainly because they are grip limited as opposed to Spec where it's horsepower limited.
I would suggest it would be hard to tell the difference by just looking at them. I do know at TITC this year different members of the team tried Raceberry, Smokem, and Samix chassis's. With so many aftermarket companies producing softer chassis then kit it would be hardly surprising to now see Tamiya produce their own softer version.
#1107
That's correct...measured from top of the axle to the setup board. Here's a link that explains this technique:
Method to Measuring and Setting Droop
#1108
I wouldn't. The car is good enough in the right hands to win anywhere.
We are talking about guys chasing the last 1%, the best drivers in the world.
There are plenty of other stuff we would all not be doing as well as they are!
If/when the X comes (it will) it will be deck changes and possibly different suspension blocks at most. Easy upgrades.
I would expect that after the worlds we will either see an X or a Worlds Edition, pending if they win or not!
#1110
Square Screw set for TRF418
