Like Tree2Likes
Tamiya TRF418
Old 05-31-2014, 02:13 PM
  #1126
Originally Posted by Johnn27
Anybody running a 418 with the soft Raceberry chassis??? Did any TRF driver run this chassis on the 418???
http://www.petitrc.com/reglages/tami...USA2014052325/
Arn0 is offline
Old 06-01-2014, 01:12 AM
  #1127
Originally Posted by Qatmix
I heard they were all running pretty much std cars, although looking at the setup it seems they are starting to understand how to get more out of the car as there are some interesting little changes to Jilles Set-up
http://www.thercracer.com/2014/05/ji...dy-set-up.html
That actually looks closer to kit set up in a lot of ways than what they were doing 6 months ago! Suspension blocks are bog standard for example.
I do wonder if, say, 2mm under the inside front camber link connection is 2mm or 3mm total (taking into account the fixed 1mm on the new hex balls). Someone should change the setup sheet to capture this!
Biggest deviation away from kit seems to be in steering links/arm connections though? And the droop setting is an obvious change of thinking!
cplus is offline
Old 06-01-2014, 12:26 PM
  #1128
d16dcoe45's Avatar
When I look at 418 setup sheets I am assuming that they are using the +1mm 418 ball studs unless specified otherwise. As far as droop settings go they look normal to me--my guess is that Jiles was measuring from the center of the outer hinge pin--in which case 9mm is about equal to 6mm measured the "standard"
way--under the arms using droop blocks.
d16dcoe45 is offline
Old 06-01-2014, 01:00 PM
  #1129
Simmi's Avatar
I wanted to try the Setup tomorrow without the droop-blocks? Is this right?
Simmi is offline
Old 06-01-2014, 03:31 PM
  #1130
Originally Posted by d16dcoe45
WAs far as droop settings go they look normal to me--my guess is that Jiles was measuring from the center of the outer hinge pin--in which case 9mm is about equal to 6mm measured the "standard"
Good pick up. It would be a change in method for him to measure that way though based in previous sheets and his posts in his thread.
I think I agree with you though!
cplus is offline
Old 06-01-2014, 05:07 PM
  #1131
d16dcoe45's Avatar
I have been running the hard Raceberry chassis on my 418 outdoors. I would like to try the soft one just to compare. I am always looking for rear bite. I have never tried the stock 418 to compare to.
Old 06-01-2014, 10:28 PM
  #1132
veecee's Avatar
Trader Rating: 34 (100%+)
The TRF guys did try them at some stage but I don't think they did after TITC. Something better came along...
veecee is offline
Old 06-02-2014, 10:43 PM
  #1133
Simmi's Avatar
The droop of 9.5 and 8 is a joke.
You need short shocks and springs to adjust this. Probably the TRF guys had the BigBore Shock from the new EVO or other Shocks
With the standard set, the setup can not be implemented.
Simmi is offline
Old 06-02-2014, 10:46 PM
  #1134
sosidge's Avatar
That's because it's measured from the middle of the hingepin.
sosidge is offline
Old 06-02-2014, 10:50 PM
  #1135
JimmyMac's Avatar
How is it a joke? That's how it's measured on the setup sheet. That's how we measure droop on Yokomo's, from the center of the outer hinge pin. Not from under the arms. If it was measure that why, it would be about 6 and 4.5 droop or close to it.
JimmyMac is offline
Old 06-02-2014, 10:51 PM
  #1136
JimmyMac's Avatar
sos beat me to it... hehe
JimmyMac is offline
Old 06-02-2014, 10:58 PM
  #1137
Simmi's Avatar
Ok guys, as rtypec a few pages back said, measuring the droop ...
Maybe you should write in the Setup
Simmi is offline
Old 06-04-2014, 04:12 AM
  #1138
Well, I hope so, I spent this afternoon getting the car ready for the next meet doing just this. If not I guess all my inner camber links are too high and my steering linkages are too far forward
cplus is offline
Old 06-04-2014, 09:13 PM
  #1139
"The tapered face of the piston provides different damper characteristics to regular flat-faced pistons, increasing your setup options."
Different how? does anyone know?
torg is offline
Old 06-05-2014, 01:27 AM
  #1140
Those trying the TRF set ups, are you using the HPI silver medium springs?
LAGuy is offline
