Tamiya TRF418
#347
I didn't bust out the caliper to check it out. I just ended up swapping them out with 6 degree ones. The C-hubs on the car seemed to look identical to the old 4 degree hubs so I just went off of an assumption. I will check it out later unless someone else beats me to it.
#351
#352
#356
I'm not aware of you guys knowing that tamiya has a solution for the problem with the 0.7mm spacer between the C-hub and the steering knuckle.
Just use the 54490 option part and you don't need that spacer thing at all.
http://www.tamiyausa.com/items/radio...e-spacer-54490
#358
#360
Nope, the TB04 manual is wrong. The 6 deg hubs still need the shim even on the tb04
http://www.thercracer.com/2013/11/ta...nd-review.html
When I built it there was loads of movement until I fitted the 0.7mm shim. I have since bought the carbon re-enforced 6 deg hubs to fit on my 418 I will try to measure them as they will be stiffer than the GRP ones that were packaged with the TB04 pro.
