Novak Kinetic
#1771
I should come down there to play and just leave my stuff there, I'm not gonna be able to run here cuz apparently the shut off valve is stuck and its just gonna rain for ever..
#1772
lipo cutoff broken
In novalink I set lipo cutoff to 6.4 volts just to be extra safe and the next thing you know my batteries are below 6v!
Yes my truck slowed down but I figured the cutoff would kick in at any moment. I pulled the thing because I was getting suspicious. I'm glad I did. I just hope my brand new batter pack isn't toast.
#1773
Same happened to me
#1774
[email protected]
On the racing ESC's, the Lipo Cutoff should "pulse" or cut out before you get to Low Voltage, if you don't stop or notice the pulsing, you can run the car past lipo cutoff.
#1775
I have run a few packs (8) through this Novak Kinetic ESC and I must say I love it! Well done Novak. I do not, as yet, have the NovaLink, but the adjustments I need for mod buggy are available through the one-touch. I'm running a 9.5 with motor timing at 20-degrees and electronic timing advance at 40-degrees starting at the 14-some thousand RPM setting. The set-up is easily as fast as my 4wd buggy with a 8.5 and a competitor's ESC (old one). The settings are intuitive and each increment is palpable. I love the temp check capability right in the ESC with a simple touch of the button; Super Handy! You guys thought of everything. The only thing I had to deal with was a power-cap module that had been assembled wrong. Novak has instructions to fix it yourself, but I chose to have them send me a replacement as my solder skills are a little lacking. No problem at all because customer service has been impeccable. Definitely a good product! Thank You!
It is a shame that so many have felt the need to emphasize the few issues this stellar ESC has experienced. If you are looking for a new ESC, this one should definitely be on your short list.
Thought you guys at Novak deserved some kudos.
#1776
And I also agree novak service is great. That is never in question.
#1777
hey all i have a new novak kinetic and 8.5 ballistic motor just looking for a set up starting point on the kinetic cheers
#1779
D3 17.5 settings
Hi all..
Wanting to use the D3, 17.5 with the Kinetic esc. installed the new brain board, Thanks thanks JRXS-R.
Large flowing out door track. We use around 5.8-6.2 FDR...Any start set ups you can help with would be great..
Not sure and dont want to kill either of them..
#1780
Hi all..
#1781
#1782
I think amazon is the best place to get that
#1783
Blades: shoot me an email with your basic vehicle and track info please. [email protected]
cats: same please. [email protected]
#1785
Usually I don't try to start out with the Boost On.
Do some basic running first with higher timing usage, then use the boost if that all works decent.
Boost is "max" timing, not a good idea to start out on max of anything.
