Old 05-06-2011, 09:59 PM   #1771
skypilot's Avatar
Trader Rating: 14 (100%+)
I should come down there to play and just leave my stuff there, I'm not gonna be able to run here cuz apparently the shut off valve is stuck and its just gonna rain for ever..
semi retired..
skypilot is offline   Reply With Quote
Old 05-07-2011, 10:24 AM   #1772
pmes's Avatar
Default lipo cutoff broken
In novalink I set lipo cutoff to 6.4 volts just to be extra safe and the next thing you know my batteries are below 6v!
Yes my truck slowed down but I figured the cutoff would kick in at any moment. I pulled the thing because I was getting suspicious. I'm glad I did. I just hope my brand new batter pack isn't toast.
pmes is offline   Reply With Quote
Old 05-07-2011, 10:29 AM   #1773
Same happened to me
dex410usa is offline   Reply With Quote
Old 05-07-2011, 12:57 PM   #1774
Charlie's Avatar
[email protected]
On the racing ESC's, the Lipo Cutoff should "pulse" or cut out before you get to Low Voltage, if you don't stop or notice the pulsing, you can run the car past lipo cutoff.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 05-07-2011, 08:35 PM   #1775
I have run a few packs (8) through this Novak Kinetic ESC and I must say I love it! Well done Novak. I do not, as yet, have the NovaLink, but the adjustments I need for mod buggy are available through the one-touch. I'm running a 9.5 with motor timing at 20-degrees and electronic timing advance at 40-degrees starting at the 14-some thousand RPM setting. The set-up is easily as fast as my 4wd buggy with a 8.5 and a competitor's ESC (old one). The settings are intuitive and each increment is palpable. I love the temp check capability right in the ESC with a simple touch of the button; Super Handy! You guys thought of everything. The only thing I had to deal with was a power-cap module that had been assembled wrong. Novak has instructions to fix it yourself, but I chose to have them send me a replacement as my solder skills are a little lacking. No problem at all because customer service has been impeccable. Definitely a good product! Thank You!
It is a shame that so many have felt the need to emphasize the few issues this stellar ESC has experienced. If you are looking for a new ESC, this one should definitely be on your short list.
Thought you guys at Novak deserved some kudos.
Banshee8530 is offline   Reply With Quote
Old 05-08-2011, 07:45 AM   #1776
macdude's Avatar
Well when your an early adopter of any new tech there are problems. And pointing them out and getting things ironed out is not emphasizing something that is not there. While I agree that the ESC is pretty great. I also have not seen a stable version of the nova link yet. The RPM range on mine still gets stuck. If you never use the novalink then you probably will also experience zero issues. That is why I recommend the Havok proSC to just about everyone. The kinetic requires a little more willingness to have stuff not work right all the time.
And I also agree novak service is great. That is never in question.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 05-08-2011, 02:27 PM   #1777
hey all i have a new novak kinetic and 8.5 ballistic motor just looking for a set up starting point on the kinetic cheers
blades is offline   Reply With Quote
Old 05-08-2011, 09:56 PM   #1778
Logi Maker's Avatar
Trader Rating: 49 (100%+)
http://www.rctech.net/forum/r-c-item...brand-new.html
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\MIP\JConcepts\Schelle\ProlevelRC
Logi Maker is offline   Reply With Quote
Old 05-09-2011, 02:14 PM   #1779
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default D3 17.5 settings
Hi all..
Wanting to use the D3, 17.5 with the Kinetic esc. installed the new brain board, Thanks thanks JRXS-R.
Large flowing out door track. We use around 5.8-6.2 FDR...Any start set ups you can help with would be great..
Not sure and dont want to kill either of them..
mikecatts is offline   Reply With Quote
Old 05-09-2011, 02:33 PM   #1780
Johnny Wishbone's Avatar
Originally Posted by mikecatts View Post
Hi all..
Boosted or None ?
Gary Lanzer
Old 05-10-2011, 01:58 AM   #1781
mikecatts's Avatar
Default reply
Originally Posted by Johnny Wishbone View Post
Boosted or None ?
Boosted..Sorry
Old 05-10-2011, 03:04 AM   #1782
I think amazon is the best place to get that
ethanhunt3055 is offline   Reply With Quote
Old 05-10-2011, 09:58 AM   #1783
Charlie's Avatar
Blades: shoot me an email with your basic vehicle and track info please. [email protected]mnovak.com
cats: same please. [email protected]
Old 05-10-2011, 12:31 PM   #1784
Trader Rating: 25 (100%+)
B4
novak kinetic 2s
ballistic 17.5 set at 30 degrees
4000mah 25c 2s lipo
75 spur and 32 pinion
boost activated with 20 degrees timing set point
Anyone see a problem with this setup or have suggestions?
I am going to run this tomorrow night at my local track.
ss_hobby is offline   Reply With Quote
Old 05-11-2011, 09:26 AM   #1785
Charlie's Avatar
Usually I don't try to start out with the Boost On.
Do some basic running first with higher timing usage, then use the boost if that all works decent.
Boost is "max" timing, not a good idea to start out on max of anything.
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
