Team Associated TC6 Thread >
Like Tree20Likes
Old 02-18-2011, 03:29 AM
  #1846
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Jeff Cuffs
Lol this was a funny topic at my track last Saturday. As per the instruction I guess I have them upside down. The ball cup is on the top side of the steering knuckle. It looks better and couldn't find any negative effects on bump steer. Have a month on the car and im amazed on how much the chassis generates traction.
From what they say the steering blocks go upside down from the tc5 if you run 6 degree caster
Warren Weaver is offline
Old 02-18-2011, 03:55 AM
  #1847
Originally Posted by walkonking
What do you guys use to keep battery in place, tape or velcro strap?
Please pose pic of ur set up.......
I use the Top Photon velcro battery strap, it was only like AUD$10 posted, but I think it was Melbourne, Aus so I'm not sure of availability overseas.
Scooter79rs is offline
Old 02-18-2011, 04:15 AM
  #1848
Castradamus's Avatar
Trader Rating: 62 (100%+)
Can someone clarify something please. In the rear of the TC5/6, If you are running 0 deg hub, a 1 mm FWD mount shim and 3.5 mm RWD mount shim. How is it possible that this equal 3.0 deg of toe? I see this repeatedly on different setup sheets.
Castradamus is offline
Old 02-18-2011, 04:31 AM
  #1849
Brian McGreevy's Avatar
I think the distance between the front and rear mounts is ~45 mm. So if you do invtan(2.5/45) = 3.1 degrees.
Brian McGreevy is offline
Old 02-18-2011, 04:47 AM
  #1850
Wow that was a better explanation than I hoped for. Thank you
Old 02-18-2011, 06:13 AM
  #1851
cas it also gives more forward bite due to a shorter wheelbase
Old 02-18-2011, 07:38 AM
  #1852
Trader Rating: 3 (80%+)
For people who are not engineers: .8mm shims will equal 1 deg of toe
Josh Hohnstein is offline
Old 02-18-2011, 10:18 AM
  #1853
Not just engineers that get taught geometry
But yes, Josh is totally correct. 2.5 mm/3.1* = 0.80
Josh, shakedown went well last night. Onto the Midwest grand slam race at Indy!
Old 02-18-2011, 10:22 AM
  #1854
xtrememadness's Avatar
Most of the factory team run em this way! Keven Hebert said you don't gain or lose anything it's more of a feel thing! And you can add washers under ball stud for bump steer! I installed them this way and should be good!
xtrememadness is offline
Old 02-18-2011, 10:29 AM
  #1855
olhipster1's Avatar
Trader Rating: 102 (100%+)
Wow...that just took me back to high school..reminds how I have forgotten
Thanks dude l.
olhipster1 is offline
Old 02-18-2011, 10:31 AM
  #1856
Buckaroo's Avatar
That's the one that I use, easy availability in the USA. Works perfectly.
Buckaroo is offline
Old 02-18-2011, 10:32 AM
  #1857
Great to hear, good luck.
I wish I could make it.
Old 02-18-2011, 07:03 PM
  #1858
Logi Maker's Avatar
Trader Rating: 56 (100%+)
PMd you about the strap, can't seem to locate one..
Thanks!!!!
Logi Maker is offline
Old 02-19-2011, 04:41 AM
  #1859
Buckaroo's Avatar
Thanks!!!!
Yeah, their parts aren't widely distributed, but if your LHS can't order one for you, you can call TOP USA directly and they'll hook you up. They used to have a web store, but it got hacked, so just give them a call. Good, friendly folks and they usually ship the same day.
Buckaroo is offline
Old 02-19-2011, 08:06 AM
  #1860
jag88's Avatar
part number please ...
Thanks.
jag88 is offline
