Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 06-26-2008, 07:41 PM
  #12796
CSF0623's Avatar
Trader Rating: 12 (100%+)
Airtronics 94360 high-speed digital servo
CSF0623 is offline
Old 06-26-2008, 07:56 PM
  #12797
EJ20's Avatar
Futaba BLS451, quiet, smooth and no glitching noise!
EJ20 is offline
Old 06-26-2008, 08:42 PM
  #12798
dizzy1's Avatar
Trader Rating: 29 (100%+)
New to the whole rubber tire on carpet thing, anyone have any good setups for rubber tire carpet, need to start practicing for IIC.
dizzy1 is offline
Old 06-26-2008, 09:22 PM
  #12799
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by ASM
I run Pro-Match's 5000 and they also require a little dremel work on the rear bulkhead too.
Just for kicks, what servo are guys running in your car? I'm thinking of getting a new one. Thoughts?
Futaba 9550 and the Airtronic 94360
The Futaba is in there now for it's smaller foot print.
STLNLST is offline
Old 06-26-2008, 10:04 PM
  #12800
RC MARKET's Avatar
Originally Posted by mild seven
I use a KO propo servo, cant remember which one but its quick and it was cheaper than the top of the line Futaba servos. I would recommend using a KO servo if you want a really quick good quality one at a decent price.
KO 2413
RC MARKET is offline
Old 06-27-2008, 08:54 AM
  #12801
diesel's Avatar
Originally Posted by RC MARKET
used Orion 30C 3800mAh with 4T bl motor & rear gear diff .
Are you using serpent S400's gear diff on your cyclone?
Thanks.
diesel is offline
Old 06-27-2008, 10:41 AM
  #12802
Trader Rating: 14 (100%+)
does anyone know where I can find purple screws?
HEWITT is offline
Old 06-27-2008, 10:45 AM
  #12803
mdttb's Avatar
http://www.fastener-express.com/inde...S&Category=218
Good place to deal with.
mdttb is offline
Old 06-27-2008, 12:25 PM
  #12804
RC MARKET's Avatar
Thanks.
before N year product !
Old 06-27-2008, 01:44 PM
  #12805
ASM
ASM's Avatar
Trader Rating: 30 (100%+)
That's what I was looking for, a smaller foot print. Thanks!
ASM is offline
Old 06-28-2008, 08:40 AM
  #12806
Default Cyclone Tc top deck
just putting together a Cyclone TC on the setup board the chassis is nice and level, as soon as i fit the topdeck it pulls the bulkheads together and i can rock the car from side to side slacken the deck of and it lies flat.
anybody had the same prob wondered if i used a topdeck from wce would this cure the problem.
Cheers
Kev-h
kev-h is offline
Old 06-28-2008, 08:50 AM
  #12807
STLNLST's Avatar
the servo doesn't hang off the side of the chassis and it's a hair lighter than my Airtronics servo so that's less weight to add to the battery side to balance the car from left to right using lipos.
STLNLST is offline
Old 06-28-2008, 05:20 PM
  #12808
ASM
ASM's Avatar
Dude, you couldn't have read my mind any better. I'm using lipos too and I'd like to lessen the weight needed on the right front. It's almost ridiculous!
ASM is offline
Old 06-29-2008, 11:35 AM
  #12809
RC MARKET's Avatar
Hara Won in Euro Championship Round 4
Attached Thumbnails Hot Bodies Cyclone-sat-1haracyclone-1.jpg   Hot Bodies Cyclone-sat-1haracyclone-4.jpg   Hot Bodies Cyclone-lrsun1modwinners-1.jpg
Old 06-30-2008, 08:17 AM
  #12810
cyclone speed's Avatar
hi i have a hot bodies cyclone moor speed WCE and i run at wlrc race track . I was wondering if anywone could help me out please .I would like to know your setup at wlrc for this car
This is my setup :
108 spur and 35 pinion
3mm spacer between the upper bulkhead and the inner pivot for front
and 2mm between upper bulkhead and inner pivot for rear
5mm front ride height
5.5mm rear ride height
5.5mm droop front
5mm droop rear
standart suspension 2 holes ,1mm each ,40w oil standart spring gold rear silver front
camber 1.5
castor 4
wheelbase is standart
and for the "dive" and"squat" is: 1.5mm under the suspensionpivot block rear
and 2mm front suspension pivot block and 1mm under rear front suspemsion pivot block dodge stratus bodyshelle
for the toe angl because i dont have the proper tools to mesaure it there is 25mm difference between each palstic thing that screw themselves to the turnbuckles
4mm ackermann
and i think thats it
for the elctronics:
lrp5.5turn gearing 7.5 (108 spur 35 pinion)with novak GTB 1st brushless profile with gemini 2 transmitter with micro 41 mhz receiver and T2M diamond digital servo (0.12 @ 60 , 13 kg torque) and finally i have 1 pack of orion SHO 4200 batteries , + 1 pack of demon ep 4200 + 2 pack of LRP hv2 vtec 4200 bigmama
and i forgot to say that i never run there when there are races i only go weekdays to practice myself
Thanks alot if you guys could help me out
cyclone speed is offline
