Kyosho SP2 WC Edition
#166
with the ST-rr ext. chassis, the truck will be much more stable in the rough sections, and has a lower center of gravity for improved handling, you will however need the longer rear tubular chassis brace, and the longer rear center universal joint, I strongly recommend holding off for the ext. chassis. If you buy the entire ext chassis kit, you get the brace, universal, and the HC knuckles, long wing stay and wheel nuts and main chassis plate all together..........dialed, and its on sale @ Amain right now
http://www.amainhobbies.com/product_...ducts_id/14166
#168
aahhhh, okie dokie.....gl finding a new buggy chassis
#169
I've bought stuff from this guy before and he's real good about sending the items out.
He also kits out parts and here's the chassis you want: http://cgi.ebay.com/NEW-Kyosho-Infer...QQcmdZViewItem Good luck bidding but there shouldn't be all that many bids.
#170
This is probably a new bid set up after the one that closed.
#171
Ryan, are their new spring rates in the works for the BB's? Maybe like something in between the lime green(hard) and purple(soft)? peace Trevor
#172
Nothing between lime green (Medium) and Purple (Soft). Our springs available and their hardness are:
White - Super Soft
Purple - Soft
Lime Green - Medium
Blue - Hard
Red - Super Hard
That is all we have currently, I wouldn't expect anything new for a while.
White - Super Soft
Purple - Soft
Lime Green - Medium
Blue - Hard
Red - Super Hard
#173
ok, thanks Ryan............I was not aware the other rates were available.......I better get to ordering
#179
BB shock building
Before you put the cap on, just press on the bladder to see that it is flexible. Some folks build the shocks with too much pressure behind the bladder. Make sure they are all pliable, and then build the shocks. You want to try and get them all the same. When bleeding the BB shocks, you need to unscrew the cap more than with the small shocks, and push the shaft in 3/4 of the way. Make sure all the air and oil has seeped out, then tighten, HARD.
That's it.
That's it.
#180
After a weekend bash at my local track here in Asia. It has been raining and I haven't had a good bash for 4 weeks. Couldn't take it no more.....so what the heck!
http://www.rctech.net/forum/attachme...6&d=1192975643
