Kyosho SP2 WC Edition >
Old 10-09-2007, 03:15 PM
  #166
Trader Rating: 66 (99%+)
with the ST-rr ext. chassis, the truck will be much more stable in the rough sections, and has a lower center of gravity for improved handling, you will however need the longer rear tubular chassis brace, and the longer rear center universal joint, I strongly recommend holding off for the ext. chassis. If you buy the entire ext chassis kit, you get the brace, universal, and the HC knuckles, long wing stay and wheel nuts and main chassis plate all together..........dialed, and its on sale @ Amain right now
http://www.amainhobbies.com/product_...ducts_id/14166
pwnzor is offline
Old 10-09-2007, 04:36 PM
  #167
khoo's Avatar
Originally Posted by pwnzor
thats cheap for a new/unused STR chassis, but the question is, do you want a standard length vs. the new ext chassis thats been released?
Hi dude,
I was actually looking for the buggy chassis. Was initially wondering if this STR chassis would fit the SP2. Anyhow some guys have already told me the STR chassis is longer. So it's a no-go for me
No worries.....
khoo is offline
Old 10-09-2007, 04:52 PM
  #168
aahhhh, okie dokie.....gl finding a new buggy chassis
pwnzor is offline
Old 10-09-2007, 09:43 PM
  #169
I've bought stuff from this guy before and he's real good about sending the items out.
He also kits out parts and here's the chassis you want: http://cgi.ebay.com/NEW-Kyosho-Infer...QQcmdZViewItem Good luck bidding but there shouldn't be all that many bids.
AreCee is offline
Old 10-09-2007, 11:37 PM
  #170
khoo's Avatar
thanks. interestingly, I just won a bid on this one just about a couple of hours ago too. Reasonable price compared to A-mains Provided we don't get bidders to keep pushing the price up.
This is probably a new bid set up after the one that closed.
khoo is offline
Old 10-11-2007, 07:03 AM
  #171
Ryan, are their new spring rates in the works for the BB's? Maybe like something in between the lime green(hard) and purple(soft)? peace Trevor
pwnzor is offline
Old 10-11-2007, 08:08 AM
  #172
Nothing between lime green (Medium) and Purple (Soft). Our springs available and their hardness are:
White - Super Soft
Purple - Soft
Lime Green - Medium
Blue - Hard
Red - Super Hard
That is all we have currently, I wouldn't expect anything new for a while.
TRCRacer24 is offline
Old 10-11-2007, 08:11 AM
  #173
ok, thanks Ryan............I was not aware the other rates were available.......I better get to ordering
pwnzor is offline
Old 10-12-2007, 10:50 PM
  #174
Zaint's Avatar
Is there any 150 cc fuel tank than can fit on the sp2? does the Kyosho str truggy fuel tank has an 150 cc capacity?
Zaint is offline
Old 10-18-2007, 02:43 PM
  #175
tht1guyinwi's Avatar
Trader Rating: 24 (100%+)
I'm having a problem bleeding my new big bores. Its like I cant get all the air out. The shock still rebounds about a inch. Any clues to what Im doing wrong?
tht1guyinwi is offline
Old 10-18-2007, 02:53 PM
  #176
The STR tank is 150cc and will fit the SP2 chassis but it sticks up too high for the buggy body to cover it.
AreCee is offline
Old 10-18-2007, 02:56 PM
  #177
Perhaps you have too much oil and not enough air (air under the bladders) that will push out the shaft rather than too much air. Unless the big bores call for it an inch of rebound is too much.
AreCee is offline
Old 10-18-2007, 06:24 PM
  #178
Maybe Im just unscrewing the cap too much and letting more air in. I never had a problem with the old ones. I'll just have to keep trying.
Old 10-19-2007, 12:22 AM
  #179
pitpop's Avatar
Default BB shock building
Before you put the cap on, just press on the bladder to see that it is flexible. Some folks build the shocks with too much pressure behind the bladder. Make sure they are all pliable, and then build the shocks. You want to try and get them all the same. When bleeding the BB shocks, you need to unscrew the cap more than with the small shocks, and push the shaft in 3/4 of the way. Make sure all the air and oil has seeped out, then tighten, HARD.
That's it.
pitpop is offline
Old 10-21-2007, 05:00 PM
  #180
khoo's Avatar
After a weekend bash at my local track here in Asia. It has been raining and I haven't had a good bash for 4 weeks. Couldn't take it no more.....so what the heck!
http://www.rctech.net/forum/attachme...6&d=1192975643
khoo is offline
