TLR 22T Thread
#4412
So far so good , perfect captive rod ends!
Here are some pic of the Mod I did to the Turnbuckle to make them Captive.
Using dubro ends I had to drill out the ball and spacer to fit the mm screws.
If someone has a better method please fill me in... I used what I had available.
No More DNF's for me!
Note the Alu rack and Trick all Alu rack guide ZERO slop no binding!
#4413
#4414
http://www.amainhobbies.com/product_...heel-Hex-Set-2
#4415
Tech Prophet
Guys they make them especially for the 22T
http://www.tlracing.com/Products/Def...ProdID=TLR2941
(the SCTE ones do work as well but you will want to get some 5mm shims and shim out the hex about .5mm which is not necessary with the 22T hexes)
#4416
This work too????
I use the aluminum clamping hexes for the SCTE, bolts right up!
I see Casper's post ^^^^^ The Friendly Ghost Thanks buddy!!
#4418
Best Parts To Upgrade To Aluminum?
I am sure everyone has broken a few parts here and there and that is what makes this hobby enjoyable as well as costly. I have a losi 22t and I love the truck to death, but I have broken a good deal of parts as well. Losi has a good way of maximizing their profit in my opinion. Lets say you break a spindle and you want to buy just ONE spindle. You have to buy both the left and right one in a package. You cannot just buy one spindle. I think it is very frustrating but also profitable on their end.
I have upgraded the steering slider to aluminum because I broke about 2-3 of them and please do not ask me how. Everyone asks me that and I cant give them an answer besides I just break it.
I know that aluminum parts are costly but when you break the same part over and over again, the aluminum part would be cheaper in the end. So all I want to know is what parts have you broken and replaced with aluminum? I want to keep it TLR only so I have all authentic team losi racing parts because I am OCD like that.
#4419
the Aluminum camber blocks are nice, the front needs to be alumnium IMO.
aluminum hexes if you feel the need. Don't worry, plenty of OCD here.
#4420
Tech Prophet
Losi offers alum in most all the parts you would be most likely to break other then larger items like arms and towers. What you end up breaking is kind of personal thing. Yes I think we have all pretty much broken a slidder at some point and time if you drive enough. It is kind of the part that gives for not having a servo saver. Is it real common or a difficult or expensive part to break. Not really.
For upgrades. I recommend the alum hexes just for the fact as they always stay on when you remove the wheels. The fronts also help with the ball cup popping. I like Alum servo posts as I feel they help support the front end better and more consistant steering. I like the alum front bulkhead and camber blocks for extra weight up front. Rear camber block for the same reason. Alum battery tray for additional adjustability (especially with short packs). Does the car work and is it durable without these things absolutely. Do they help, I think so otherwise I would not use them.
One other thing the one piece king pins for the caster/spindle joint do help strengthen those parts. I also use this same pin for the arm to caster block joint. I put a 2mm spacer on either side of the arm to take up the extra space. Makes all that area bullet proof without the expense of alum.
I will be posting all of this up at www.casper-rc.com shortly with some pictures. Getting all the pages setup as time permits this week so check out the new web site for other tips and tricks as well as all my std setups!
#4421
plastic replacement parts are cheap, $5-10, and if you can't afford to fix it after you crash it either you need a different hobby or stop crashing so much.
blaming the car isn't right. i've had my 22 buggy for over 2 years now, and my 22T for over a year, and during that time and racing almost every weekend I've broken one part. a steering rack. just one. anybody that's breaking as often as it sounds you are needs to slow down and start aiming to miss things instead of aiming to hit them.
adding aluminum replacement parts is good if you're not breaking a lot of parts, but adding them as a bandaid for your bad driving is never the answer as it always leads to breaking something else in in opinion.
#4423
Think i found him wayyyyy in the front
#4424
I dont think I was blaming the car but if it sounded like I was then I apologize. The vehicle is awesome in my opinion but one thing that I have a hard time with is putting the front end back on when I remove it. Not losis fault I dont think but I think I do it in a way that others may not. Anyways, I think the truck is durable but I just need to hone in on my driving skills. When I break parts, usually it is at the same part of the track.
i've never seen any brand of rc car that sold individual right or left side spindles, they always come in pairs. same thing with any suspension piece. it's not a TLR thing, it's like that with any brand.
#4425
And just to let everyone know...since I upgraded to the aluminum steering slider and titanium turnbuckles with the threaded king pin, I did not break anything last race day. haha. But when I do break things they break because for one my driving skills are not as good as they were a few years ago but secondly I will hit something hard. For example; at my local track there are plenty of jumps but then there are poles made out of steel and a barrier. I cracked the bulkhead but it is not completely broken because when someone bumped into me before the jump I went off the jump on the right side and hit the steel pole in mid air. Surprised I didnt break anything else besides the bulkhead. I broke the rear spindle piece too becuase when I took a jump wide I didnt have enough power to clear the barrier completely and I clipped the barrier and broke the spindle. Both crashes were nothing to complain about and were very cheap (maybe 6 dollars). I dont care how much I pay to fix parts because I love the hobby but when I break the same piece a few times and the alumimum part is available, I will get that part. So far the aluminum part that I purchased (steering slider) has done me very well!!!
